Question about Casio Cassiopeia E-100 Pocket PC
E-100 Serial Connection Question
Is there any way to change the speed of the serial connection from 19.2? I tried going to the COM1 port settings and changing that to 115 or a different value, but that doesn't seem to work. Anyone been successfull connecting at a speed that doesn't drag as much ass? Thanks.
    Master:
  • 551 Answers
Actually the procedure is a little different. On your desktop right click My Computer, select properties. Select Device manager tab. Expand the ports. Right click the COM1, select properties. Here you can set the device speed to 115000 bps. Repeat the procedure for COM2. This works on all versions of Windows. On XP you will have to go through Control Panel - Administrative Tools - Computer Management. Restart your computer. On your PDA you can set the speed on the connection page in active Synch only if you turn on the Auto Synch option. The 115kbps is at the top of the list, above 19 kbps setting. I have been using these settings for a couple of years now with very good results. Hope this helps. Reply With Quote
Posted on Sep 05, 2005
    Master:
  • 551 Answers
Go to your device manager in your laptop/desktop, then click on modems, then click on communications cable between two computers, then click on the modem tab and change the speed to 115200, then reboot (it doesn't say you have to but you need to). Change the speed in the casio communications to 115k and then sync. Reply With Quote
Communication port is not working properly
COM1 and COM2 refer to a computer's communications, or serial, ports. COM1 ports are often used on older PCs to connect network devices, digital cameras and mice. Faulty drivers software that enables the hardware to communicate with the operating system or incorrect hardware configuration can influence COM1 behavior. In rare cases, the expansion card that adds the serial ports to the PC can fail, rendering both COM1 and COM2 ports useless. To repair a COM1 port, you must determine what is preventing the port from working before attempting a solution.
Click "Start." Go to "Control Panel" and then click "Hardware & Sound." Select "Device Manager" from the submenu. Expand "Ports (COM & LPT)." Double-click "COM1." Review Device Status on the General tab to check for problems with the software driver. If the message "The Device Is Working Properly" appears, click "OK" to close the window; otherwise, look up the error message on Microsoft Support. Follow the directions in the Knowledge Base to correct the issue. Press "Alt" and "V" to open View. Scroll to "Resources by Type." Press "Enter." Double-click "Interrupt Request (IRQ)" to see a list of devices. Double-click "Communications Port (COM1)." Check the term to the left of COM1 to see if the card uses an ISA or PCI interface. If the card uses a PCI interface, it can use the same IRQ as another PCI device without producing a hardware conflict. If the device is ISA, it needs its own IRQ. Go to the "Resources" tab. If "No Conflicts" appears in the Conflicting Device List, close the window; otherwise, uncheck "Use Automatic Settings." Click the drop-down menu and select each configuration until the port no longer interferes with another device. If conflicts occur with each configuration, double-click "IRQ"; you may need to try different configurations before Windows gives you permission to edit the interrupt request. Click the up or down arrow to change the IRQ until the message "No Devices Are Conflicting" appears in the Conflict Information field. Click "OK" to close each window. Click "Yes" when prompted. Connect a device to the COM1 port to test the port. If the device doesn't respond, shut down the computer and then unplug the power cable. Disconnect all devices from the back of the PC. Remove the case cover and touch the computer's chassis. Set the computer on its side so that the PCI and ISA cards sit at a 90-degree angle to the floor. Find the serial ports on the back of the PC. Look on the opposite side of the case to find the associated card. Shine a flashlight onto the card and make sure that the copper contacts are not visible. If you can see the contacts, reseat the card in its slot so that it's fully installed to the motherboard. Reassemble the case and boot into Windows to test the COM1 port. If the port still fails to work, you may need to replace the serial port card.
Jan 16, 2013 | Computers & Internet
I have the same printer, and xp on my pc, but how do i connect them? my laptop does not have a serial conection. i tried to use a usb/serial converter and i installed the xp driver from minolta website,...
You need to make sure you have selected the correct COM port whin you try to print. Depending on the type of USB to serial converter, the COM port it assigns can change just by moving it to another USB port. Right-click on My Computer and select MANAGE. Select Device Manager from the list. Click on the (+) next to PORTS and double-click on your USB-SERIAL device COM port. Somewhere in the Properties window you should be able to see the assigned COM port (COM1, COM2, etc.). If possible, set the COM port to COM1 or COM2 for greatest compatibility with older software. Then when you print, make sure your printer driver is also set to the same COM port.
Mar 05, 2011 | Office Equipment & Supplies
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
Problem with serial connection with AMD motherboard
Software that accesses serial ports usually allow you to specify WHICH port you want to connect via.
Your new board should have COM1 and possibly COM2... but perhaps your old setup was running from COM3?
Connect the Casio to COM1, and check the software you are using... set that to "look" at COM1 also. That should work!
Apr 20, 2009 | Casio Serial RS-232 Cable (CELL-300)
MS9520 serial connected to the terminal - does not send keys to the terminal server
Ok this is an old questions, but I had a similar problem recently. I found that I had to install Softwedge on the Remote computer.
I was trying to use the scanner over remote desktop. Remote dektop needs to have serial communication enabled. The computer that you are connecting to via RDP needs to have softwedge installed.
Nov 07, 2008 | Metrologic Instruments 9520 Voyager
Hyperterminal
bring up hyperterminal it will open a connection window if there is a modem inyour system it will default to it select in the down arrow to the left com1.
this will open the com port window.
at which time you should select the settings accroding to your connection. bits persecond data bits flow control. all this should be within your installation instructions.
good luck
Jun 24, 2008 | Quatech SSU-100 Serial Adapter
Pentium III 800 mhz T21 Thinkpad Internet connection problems
why fight it , let it be on com 1 then,
go into the bios and disable the serial ports .
that may be the easiest fix as long as you don't need the serial port for anything.
but if you have a serial mouse oh boy.
May 13, 2008 | IBM ThinkPad T21 Notebook
USB-Serial Adapter
You have to setup the com prot for the serial connection to be recognized.
Go to the system ICON in the control settings.
Select hardware tab then device manager
you'll see the com ports select com port one
right click and select properties then the port settings tab.
Check you product adapter and make sure you have set the speed settings, data bits, flow control according to manufactures specs. save and this should solve you problem.
note: make sure there is no other peripheral operating on your system this may be utilizing your comports and restricing your connection.
good luck.
Oct 02, 2007 | Quatech SSU-100 Serial Adapter
F505 serial connection is dead.
Had the serial port working before? If not, try this, disable the infered port and click start choose IBM Thinkpad 760 open it and locate the com1 (serial) and enable it. It should work fine. Goodluck.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Casio Cassiopeia E-100 Pocket PC Logo
107 people viewed this question
Top Casio Computers & Internet Experts
k24674
Sunil Pratap Singh
Sunil Pratap Singh
Joseph Hoffmann
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
