Question about Kitchen Appliances - Others
Honeywell Central Heating Timer ST699
My central heating and hot water aren't working on my return from holiday and I suspect that the timer's at fault as it had blown a fuse. How do I test it?
In the end I bought another timer on sale/return. My heating didn't work with that one either, so my problem's not the timer but something else.
Posted on Aug 27, 2008
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
How do i set the heating/hot water timer on the LP112-24 acl controler ?
The instructions are available here: I hope I have been of help but please do not hesitate to ask if you have any further questions. Set the central heating Press the YES button, and the display will ask 'SET CH PROG?'. Press YES and you'll see ON1, the start of your first central heating period. Adjust it in 1-minute steps using the - and + buttons. If the - and + buttons are held down, the time changes in 10-minute steps. Press SET?, and you'll see OFF1, the end of your first central heating period. Adjust this in the same way, press SET?, then repeat the procedure for ON2, OFF2, ON3 and OFF3. Set the hot water When you press SET? after setting OFF3 for the central heating, the display will ask 'SET HW PROG?'. Press YES, then set your times in the same way. Remember, in this mode you can have different times to your central heating if you wish. When you press SET? after setting OFF3 for the hot water, the programmer will return to normal operation.
Feb 19, 2011 | Heating & Cooling
Cannot set timer on central heating/water system.
Go to
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jul 27, 2010 | Honeywell Heating & Cooling
Have a back boiler. Central heating working fine. Hot water not.
Depends on type of control system but usually you will have a three-way motorised valve somewhere. This is contolled by the tiimer and the thermostat on your cylinder. Look for a box that has one pipe going in to it and two further pipes coming out. I suspect yours is stuck on heating. Some models had a manual lever to put it to just hot water. End of the fday you need to get someone out to fix this one.
Jun 16, 2010 | Heating & Cooling
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
I have a honeywell ST699B controller for my central heating & water, i walked past it today and the light that indictes the water is on was illuminated. The water is set to come on once a day but not...
i have an st699 programmer its set to go on twice a day heating up but when the wife gets up after ive gone to work the timer is not at the correct time so no heating any ideas as new ones expensive to buy
Jun 25, 2008 | Heating & Cooling
Central heating timer
Does it have batteries?
Apr 05, 2008 | Heating & Cooling
Kitchen Appliances - Others Logo
375 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
