Question about Apple 20" Flat-Panel TFT LCD Cinema Display
Apple 20" display black screen
I have a 20" Apple Cinema display monitor I just hooked up to my G4. I  connected the monitor (using a DVI extracter II cable adapter). I started the computer and the monitor came on, showed the gray apple and spinning wheel for 10 seconds or so, then the screen goes black.
  • 2 more comments
  • Rochafan Jan 10, 2009
    Exact Same Problem! Can anyone help?
  • Jamoze Mar 22, 2009
    Every once in a while my apple 30' display has a problem, the screen just goes black. To solve this issue I unplug the power cord 150w power adapter and plug it back in, this solves the issue and the display comes back on. Why does it do this?
  • pbeck May 11, 2010
    Which OS are you running?
    What model of G4?
  • Anonymous Mar 21, 2014
    Computer stays on for couple minutes then shuts off
  • 35 Answers
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Posted on Aug 17, 2009
May I Connect Apple 20" Cinema Display to orignal MacBook Air( does not have a Fire-Wire port)
Yes, you can do this. Firewire is not necessary. That is for connecting your hard-drives should you want to do it through your display.
Dec 18, 2012 | Apple 20 inch LCD Monitor
Add a 22" Apple Cinema Display to an Ibook G4
use the video toggle key to transfer the picture to the cinema screen..
Sep 21, 2008 | Gefen ex-tend-it The VGA to ADC Conversion...
Apple dvi to adc adapter wattage?
The 65W is for the 20" ACD (aluminum clad Apple Cinema Display)
The 90W (A1097)is for the 23" ACD
The 150W (A1098) is for the 30" ACD
Jul 06, 2017 | Apple Computers & Internet
Apple cinema display has interference
Check your DVI cable for breaks. If that's not the problem, then you'll need a new IP board. Not sure of the part number for this monitor, it's printed on the circuit board. It starts with 820-XXXX or 620-XXXX in some cases.
Nov 24, 2009 | Apple Cinema 20" LCD Monitor
Apple Cinema display goes BLACK after start-up
My G4 has a ADC & VGA on the same card. The VGA works but the ADC, is doing the same thing as you described. I am searching the web, and can not find an answer to this problem. George 3/21/2010
Aug 03, 2009 | Apple Cinema Display Flat Panel Monitor...
Can I use an Apple M7649 Studio Display with a MacBook Pro
Do you have the black unibody Macbook Pro that was just released, or the silver model?
Since the display is DVI, it will directly hook up to the silver model. If you have the new model, you need a mini DVI to DVI adapter.
Nov 22, 2008 | Computers & Internet
Re: Video Card TOAST???
Given the environment and issue, sometimes a solid way to process of eliminate, is to add a display to the laptop. Laptop videocards are embedded/integrated in the motherboard/logic board. So, your Mac has not been specified. This provides for many variables. I'll keep this simple but thorough.
First, monitors. Unless you have a great hook up from the next level, you will most likely have a:
  • VGA monitor. if the monitor has the cable attached to it, and not via connectors, but actually runs into the back of the monitor, odds are it's VGA.
  • DVI monitor. Most DVI monitors do have atleast a VGA input.
DVI is digital and far more robust, but the cables and connectors might not outweight what you gain from it if you're not using it to, watch movies, edit video and or edit high resolution photo. If you already own a DVI monitor, then I feel the cable ( if 3-6 ft) and the "possible adapter"
($20) is well worth enjoying what you've paid for.
The "possible adapter" is a white (made by Apple for Apple) proprietary adapter that is required to connect any Macintosh laptop that IS NOT of the ALUMINUM POWERBOOK or MAC BOOK or MACBOOK PRO series, to a monitor. All recent Macintosh laptops ship with 1 form or another of a video adapter.
  • Mini VGA to VGA
  • Mini DVI to DVI
If you need to cross over VGA to DVI and DVI to VGA adapters are available, but you will then have to make note of the gender of the connecting port or cable end.
So, if you own:
  • A white G3/G4 IBook, the video output connection is MINI VGA.
  • Older Titanium Powerbooks, pre 667Mhz have a standard VGA on the rear.
  • 667Mhz-1Ghz Titanium Powerbook, all Aluminum Powerbooks, and ALL Macbook Pros have an on-board DVI female ports. In the rear for TIbooks and Rear right side on Aluminumbooks and MBPs.
  • All Macbooks utilize mini DVI.
SO, ON WITH THE QUESTION PLEASE!!
Connect a display to your laptop. If you get a picture, than more than likely, any component from the cable that runs from the motherboard, up into the display panel, to the inside of the display, is faulty.
If you do not get a picture, than its highly possible the video card or GPU has failed.
If you could specify your model, I can further assist you.
Sep 02, 2008 | Apple iBook G3 Mac Notebook
Apple 20" Flat-Panel TFT LCD Cinema Display Logo
499 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
