Question about Refrigerators
My 6yr. old LG fridge/freezer (GR-621RW) has started leaking water. There is a drip coming from a small 'drainage hole'? at the top of the fridge. Water accumulates at the back of the top shelf and then runs down under the bottom drawer and out on to the floor. After mopping it up, it takes about 2 days to pour out on to the floor again. There doesn't seem to be any way to unclog a drain as the back of the fridge is solid. How can I solve this problem?
  • Anonymous Jan 17, 2009
    my eight year old whirlpool top freezer refrigerator leaks from the top down in bottom ;the drain seems to be stopped and there is no way to take the back off the get to the drain tube,it dose not drain now.
Maanita
  • 1142 Answers
SOURCE: Water colecting on floor of freezer in
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Mar 24, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Water is accumulating in bottom of fridge under produce drawers
Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Posted on Mar 28, 2009
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: water leaking from bottom of fridge (freezer) onto floor
This is a very common problem and has several reasons that may cause the problem. I have a lot of information that covers the different ways that this takes place and hot to to resolve the problem all on one page. So read the complete page and choose the part that most fits your refrigerators condensate overflow. Thanks, Sea Breeze
Click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 16, 2009
  • 10865 Answers
SOURCE: Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Posted on Aug 22, 2009
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
May 23, 2010 | Whirlpool Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water leaks from the freezer area to the fridge
Check your drip pan and the nozzle of the line and see if it is dry. If it is dry you got a clog like I did.
I solved my own is the line from freezer to the drip pan was clogged with ice. Just remove the two back screws in the freezer section and melt the ice using hot water from the tap and maybe use a light pump could be a small foot pump nothing to powerful to put in the hole and pump until you see the water come through.
Aug 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
LG Bottom Freezer Frost Issue
It sounds like your defrost controller has gone bad. I have an LFC25760 and had ice build up in the bottom of the freezer such that water would start leaking onto the floor. The ice build up in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
Jun 22, 2009 | LG LRFD25850 French Door Refrigerator
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Jan 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Hello help People, Water is dripping very slowly from the back of the fridge ceiling seemingly coming from the drain in the freezer? We cleaned out both the freezer and fridge and allowed for some...
maybe the drain is blocked further along - at the rear of the fridge. Sometimes there is a small bend or elbow in the drainage system that blocks.Check the outlet to see if water is actually coming out at all.
May 04, 2008 | Refrigerators
Refrigerators Logo
373 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
