Question about Casio Cassiopeia E-100 Pocket PC
Time to replace the battery already?
Hello, Lately my E-100 have been shutting down only after less then 10 mins. of use. I have a compact flash card which maybe taking up some power. Has anyone have any specs. on how long is the battery life altogether. Also, normally how long does it last before you have to re-charge again with and without CF. Is there some way to tell for sure that it is the battery issue before I get a new battery? Also, where can I buy it cheap and not have to be on the waiting list? Sorry for too many questions. Thnx in advance, JP
    Master:
  • 551 Answers
Don't know about life on your unit but most run 3 hours plus, depending on the unit. I have one that does 3 and another that is supposed to do longer. You might pull your cf card and charge the battery and run the unit for the ten minutes and see if it will last. It could be that it is drawing a lot too much power. Now, this MIGHT give you indication of whether it is the battery or the unit itself, but don't know for sure. To run it down from a full charge in that short a time should make the battery quite warm so if you can get to the battery run it down and feel it to see if it is getting hot. If it is there is probably something wrong in the unit. If the battery isn't getting hot then I would say it could be a bad battery or it could still be the unit itself. If the unit works okay on the charger, I'd guess it is the battery. Cheap batteries - just look around and call around. We have a company called batteries plus here that has all sorts of odd batteries. You might check radio shack as well, they might have something that would fit.
Posted on Sep 05, 2005
Battery low while already plugged in
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 25, 2012 | Dell Vostro 1000 Laptop
Hello, the battery on my dell vostro 1500 is fully charged, at 65% of its life and passes the dell diagnostic tool, but.. when i take out the plug the battery fails in less than 5 seconds. any help is...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Dell Vostro 1500 Notebook
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
HI, I have a motorola q 9c cdma, lately when i try to make a call it displays an error message that cant make the call, but it have full signal. I turn of the phone and turn on again and it works fine for...
yes the way that you can change the phone volume without doing a master reset is by: pressing and holding down the toggle button on the side of the phone then scrolling the volume to the highest point.
Nov 13, 2009 | Motorola Mobility Moto Q
Unexpected shutdown with fresh battery ...only cycled 23 times so far. Mac shuts down after about 3 minutes....then shuts down on boot sequence after that. No warning...just shuts down instantly. Macbook...
"Shuts down instantly without warning" is the hallmark of a faulty battery. "All five lights on" is meaningless, as batteries with this fault go from 100% to 0% in a finger-snap. Assuming your battery is under warranty, it should be replaced at no charge.
Nov 08, 2009 | Apple MacBook Pro Notebook
I have a philips 27'' and lately my tv been shuttin off like 10 mins. after i turn the tube on, she is about 6 yrs. now. i perchased new at fry's electronic's 2003. iv'e blew it out thinking it might have...
Ur hight voltage transformer have cold soldiers,that why some time u able use long time some other time u can't.The FBT(The block of plastic with a red wire with a cap that hook to ur CRT(UR TV TUBE).The part needed be reseat it,and resoldiers.
Aug 26, 2009 | Televison & Video
Cranks as though battery is dying
That sounds like your alternator might need to be replaced.
Dec 18, 2008 | 1988 Yamaha XJ 600
Coffee maker timer does not keep the heat plate on after 10 mins.
I was able to fix my little problem. I unplugged my coffe maker and waited 'bout 10 mins for the whole thing to shut down. Once the clock shut off, I reset the time. Secondly, I pressed the on/off button and held it in for 2 seconds until the red light started flashing. I set H to 1 and M to 59(I have never seen this before). anyhoo, afterthat, I set the timer to the exact time I wanted to smell my freshly brewed coffee. This morning, the red light seemed to stay on and kept my coffee nice and hot.
Nov 25, 2008 | Braun AromaDeluxe KF 580 Coffee Maker
Card Error?
i think you have broken or bended any of the pin inside the card slot, and that is creating problem. Try looking in the card slot you may find any of the connector pin broken or bended. Try straighten the pin cautiously and may your machine start working .
Aug 16, 2006 | Fuji FinePix S7000 Digital Camera
Casio Cassiopeia E-100 Pocket PC Logo
152 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Computer Links
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
