Question about Aspire AD-8000 (Open Box) (AD8000OB) Burner
Burning music playlists onto cd
While burning music cd's it says "initializing" without any problems. After that it says "writing" for each song. Every time it writes a few songs and then an error occurs and it cancels itself.
  • tahaelhassad Jan 17, 2009
    How can I copy songs from my playlist onto a cd ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Sounds like you need a cleaning or your cd dvd players is ready to take a leap..lala linda
Posted on Aug 26, 2008
Cannot burn audio cd with iTunes
Maybe iTunes don't want your burning their music. I'm not sure cuz I don't use Itunes, but if it works on others that sounds like it might be the problem.
Here I found the below on Apple's site.
Symptoms Find out what to do if you can't burn an audio CD using iTunes for Windows. Sometimes an audio disc may not burn as expected. Here are some things to check.
Resolution Update iTunes Download and install the latest version of iTunes for Windows.
Songs not authorized iTunes will stop burning a disc if one or more of the songs in a playlist were purchased from the iTunes Store but are not authorized to play on this computer. This message appears:
"Some of the files can not be burned to an audio CD. Do you still want to burn the remainder of this playlist? For more information on why some files can not be burned, click below".
There's more so click the link below and see why you can't burn your cd.
http://support.apple.com/kb/TS1436
May 09, 2012 | Dell Optiplex 755 Desktop Intel Celeron...
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
When I try to burn a disk it tells me I have to check each song individually. This is crazy. Isn't there another way. Select all doesn't do it.
What to do is to create a new playlist. Then go to your music library and from here you can drag the tracks that you want to record onto the playlist. Once you have select all your tracks you can then burn that playlist to CD. Hope this helps.
Nov 13, 2010 | Apple iTunes
Burning a disc
please 1st you install a burning software and then burn you disc.
Aug 11, 2009 | Apple iTunes
Why Won't My Toshiba Satellite Laptop (A200 -AH3) Not Burn Discs?
Look for any software on the machine that uses the the burner. Start by updating it (many of these programs use what are called burning engines to process the request to write to a cd, and if theyre damaged, then the writing process will appear to occur, but wont do anything). If you use programs that download and manage music (such as Limewire, Bearshare, or Napster), uninstall them.
As a last ditch effort, you can try the istructions in this Microsoft article:
http://support.microsoft.com/kb/314060
Be warned, you will have to reinstall the software needed to burn your CDs if you do this. It has fixed 99% of CD burning issues out there. Good luck
Mar 05, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba laptop won't burn cd from itunes
I think it might have to do with Toshiba's OEM version of windows that is put onto the laptop. There is so many programs installed normally that i think theres system files that are incompatible with certain programs that require them. Probably a retail version of windows then installing just the drivers for the hardware and install just the software you want would take care of the problem in that way.
In the meantime though my other suggestion would be to use a program like Nero or Roxio Media Creator to burn your music onto cd's. That could do the trick.
Feb 08, 2009 | Toshiba Satellite L305D-S5881 Notebook
Downloading my music and then burning to a cd
Have you read the section of manual relating to 'Importing CDs' ?
Select a playlist, press 'playlist edit' - press HD/CD - insert CD, close drawer. Once Alesis has scanned disc, press 'track move' - display should read Move CDTrk -> Trknn where 'nn' is the next available track in playlist. Press Cursor Left to place cursor under CDTrk, press Down/No, and display should read Move CD->Playlist. If you now hit Yes it will copy all CD tracks to the active playlist (it'll prompt if the playlist isn#'t empty to make sure you want to add the CD to the tracks already in the playlist).
Once they are copied to the playlist, you can move them around if required, DSP them, then burn that playlist to a blank CD
Dec 02, 2008 | Alesis MasterLink ML-9600
''i want to burn mp3 music on cd for my car stereo, but it won't p
if you went to 'audio burning' in nero and chose 'audio cd' then you should really not have any problems because it will play on any cd player. If you still have trouble with this though try burning an audio cd in windows media player instead. Create a playlist, it cannot be longer than 70 mins (i normally max at 68 minutes) then select burn playlist. This should play in your car with no problems.
I hope this helps
Nov 11, 2008 | Ahead Software 8 Ultra Windows
BURNING ITUNES MUSIC TO CD
Itunes does have digital rights management, which restricts the number of times you can burn the tracks you've downloaded. It's one reason I prefer sites like mp3fiesta.com who don't believe that if you've paid for the track you should be restricted in using it.
To burn music from Itunes you first have to make a playlist of the tracks you want to burn. Select New Playlist on the left, and drag the tracks you want to burn into this new playlist. When you've done that, right click the playlist name and select "burn playlist to disk."
This will ONLY work a finite number of times (I believe currently it's either 3 or 5) after which burning will be disabled for a track, and if that track appears on a playlist you won't be able to burn that playlist either.
May 12, 2008 | Dell Inspiron 1501 Notebook
Downloading music
you need a program called itools.It will enable you to do swapping of music.The cd prob is another issue.Your computer might be finalizing the cd,which doesn't allow any music to be added.
Nov 21, 2007 | Microsoft Windows XP Media Center Edition...
Computers & Internet Logo
67 people viewed this question
Top Aspire Computers & Internet Experts
Jax Planet
Jax Planet
Joe Goldman
Joe Goldman
john smith
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
