Question about Radio Communications
Car Radio My son is fitting a new car radio in a Vauxhall Corsa. The pre-set stations disappear when the engine is turned off. I take it this is an electrical fault, any idea where he should start looking please ?
    Novelist:
  • 100 Answers
Yes, my best bet is that there is no constant power going to the radio. Usually car stereos have 2 power wires. Generically, they are yellow and red on most major car stereos. The yellow wire needs to be powered at all times and the red wire needs to turn on when the car turns on. It is possible that you have them switched around. It would still work if you have them switched just wouldn't hold any memory. If they are correct I would search for a blown fuse. Make sure to check EVERY fuse. If you need further help, let me know the make, model and year of the car you are installing into and the model number of the stereo and I can tell you exactly what you need to do. Good luck.
-Andrew Hawkins
Posted on Aug 26, 2008
Car radio not picking up stations
Check the radio earth, the aerial cable and the point at which the cable reaches the aerial.
If there is no fault, take the radio back to where you bought it.
Jan 20, 2014 | Car Audio & Video
Memory problem
Make sure the yellow wire is going to a constant power source. The yellow wire controls the memory and needs to have power going to it even when the key is off.
Apr 21, 2013 | Car Audio & Video
Can I buy a VR500CSBT connecter to female ISO connecter to fit VR500CSBT in my Vauxhall Corsa as I don't want to cut the indvidual wires of the conecter that came with the stereo and join it to an
they sell wiring harnesses that connect to the car manufacturers radio/player harness with wires to connect to after market players, do they sell one for your car? not sure
Mar 10, 2013 | Roadmaster (VR500CSBT)
Why does my radio on a Corsa Design 2007 only pick up the bbc radio channels? I have just bought the car.I have no arial on the top of the car.
You should have an Aerial mast on the roof of the car, it should be situated at the rear of the roof in the centre. All Corsa`s come fitted with an Aerial as standard so it should be there. If it is missing or broken then you will only be able to pick up the BBC stations as they have the strongest signal strength.
The Aerial consists of a base section attached directly to the roof and a mast which is removable from the base by simply unscrewing it, it`s not uncommon for the mast section to get pinched as it`s easily removable but they can be bought separately from any any vauxhall dealer and are easily replaced.
Hope this helps and thanks for using fixya
John
Dec 23, 2010 | Car Audio & Video
Radio code vauxhall corsa 03
Sorry...this code will only be available from the Main Dealer or a Radio Decoding Service.
Will not be available for free from anywhere on the Internet
Jun 15, 2010 | Car Audio & Video
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
May 07, 2009 | Car Audio & Video
Radio code for vauxhall corsa
The units anti-theft program was activated when the battery was disconnected. If you don't know the 4 digit code, try to contact the previous owner or most higher end car audio dealer/installers will offer a service to reset the anti-theft code program, for a fee.
Aduz
Mar 25, 2009 | Car Audio & Video
Radio code
there is now way u will get the code from any one but vauxhall as everyones is different 29.99 is the cost 4 a new security pass and they will put it into the radio 4 u
Dec 06, 2008 | 1990 Volkswagen Passat
Radio Communications Logo
81 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
