Question about Samsung DLP HL-P5663W 56" TV
Remote stopped working after color wheel replaced
I have a dlp Samsung television. The color wheel was replaced in it, and since then the remote will not work to turn the television on or off, but it will work once the television is on. Please help!
Hasti
    Problem Solver:
  • 6 Answers
See http://www.consumermeet.com/entry/samsung-remote-wire.html , that seems to address the same problem.
Posted on Aug 30, 2008
I have no jumper on my samsung dlp to change colors back after changing the color wheel.
hi,,
after the color wheel replacement you need to get the restore sequence procedure using button combination of your remote..
try to to this link www.fixya.com/users/chester_pendilton0
and get any of my services..
thanks
Feb 03, 2012 | Samsung HLP6163W 61" Rear Projection...
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My rear projection samsung tv dosent turn on it has just stopped it makes a squeaking noise and the light flashes then nothing.. # has any body seen this problem before
The color wheel is acommon fault with Samsung DLP TV's and cause the symptom you describe.
check the link below to see if your model# is listed.
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 24, 2009 | Televison & Video
I have a samsung dlp that makes a horrible buzzing sound and it turns off, all the lights blink and the color flashes in and out.
The problem is likely the color wheel paste the link attached for more info
Samsung Color Wheel
Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Hlp4663w color wheel
Check
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 29, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
Sep 29, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
