Question about Kicker Car Audio & Video
I have 2 kicker 07CVR124 12" dual voice coil with a 800 watt mono pioneer amp. How do I wire it correctly
    Novelist:
  • 100 Answers
I'm not sure what pinoeer amp you have. If I remember correctly some are 1 ohm stable. In this case you would be able to wire everything in parallel. Meaning, with the voice coil, wire the positive to positive, and the negative to negative. Then wire the subs together positive to positive, and negative to negative. This will give you the total impedence of 1 ohm. If it isn't 1 ohm stable the best you could do is 4 ohms. To do this you would need to wire the voice coils in series and the subs in parallel. Meaning, wire the negative to positive and the positive to negative. Then take the subs and connect the positive to positive and the negative to negative. I hope this isn't too confusing. If you need further assistance let me know. Good luck
-Andrew Hawkins
Posted on Aug 26, 2008
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do you wire 4 kicker cvr dual voice coil 4ohms to a 1500.1 kicker mono block 1 channel amp, they sound distorted when i turn them up, how should i wire them?
Hello antjobe,
According to Kicker the 1500.1 is only stable to 2ohms. So you will want your 4 CVR's to present a 2ohm or higher impedance to the amp.
The best configuration would be to wire the voice coils in series (each sub 8ohms) and then parallel all of the subs to the amp (2ohms). Here's a link to the diagram.
Hope this helps.
Jun 08, 2009 | Kicker CVR12 Car Subwoofer
Sony xm-D9001GTR mono and kicker 4ohm dual voice coil
its a good amp but dont power ur amp at full put it at about half power
May 27, 2009 | Sony XMD9001GTR Car Audio Amplifier
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
How to install..........
COMTE UNA VERGA GRANDISIMA WEY Y SE CONNECTAN SOLAS IJUUUUUSU CHINGADA MARDEEEEEEEEEE
May 07, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
159 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
