Question about Whirlpool Designer ACU109PR Thru-Wall/Window Air Conditioner
My through the wall whirlpool air conditioner has water sprinkling through where the cold air comes into the room is my air conditioner broken??
  • Whirlpool Master
  • 43,501 Answers
No... either the drain hole is plugged or the unit is tipped forward instead of backward...make sure that the unit outside the window is lower then the inside by just a bit... The drain holes are usually in the back outside corners and often they plug up with dirt or debris...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble
- Review the Possibilities
heatman101
Posted on Jul 12, 2011
Testimonial: "i had just defrosted my air conditioner so the melted ice was kicking it up and out of the unit "
SOURCE:
Ac exhaust fan
Yes for dehumidifier, no for heat mode. In dehumidifier mode all the unit does is takes air in, runs it through the evaporator (cold) coil and the back through the condenser (warm) coil discharging dry, slightly warmer air back into the room. In heating mode however if you don't vent the exhaust there will be no heat produced. Warm air will come out the top but cold air will also come out the exhaust (essentially, in heating mode all it does is operates as an air conditioner in reverse. Hope this helps.
Jan 11, 2014 | Whirlpool ACP102PS Portable Air...
Should my 10,000 btu window air conditioner be leaking water all over my balcony
Air conditioners put out cold air, exhaust hot air, and produce condensation when they are in use. The condensation is the water that is dripping out of your air conditioner.
Your air conditioner is not broken, but it would be wise to determine a way to direct the water off of the balcony.
May 22, 2011 | Whirlpool Heating & Cooling
Water coming into residence, front of ac icing up and doesn't appear to be blowing cold air..
The icing up can come from a dirty air filter or from the unit leaking freon and being low on charge...
The other way to freeze it is to try and make the room too cold...
check the filter... don't try to get the room colder then say 70 and if it still freezes then you have a problem...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 01, 2010 | Whirlpool ACQ294XJ Air Conditioner
What's the difference between dry and cool setting and when should dry be used
Dry is a dehumidifier option. There is a heating element in the unit to heat the cold air back up. The cold evaporator coil causes the moisture in the air to condense on the coil (this is why the AC leaks water) and the air coming out of the vents will be cold. If you are not wanting to lower the temperature in the room but want to take out the moisture then use DRY. All ACs take the moisture out of the air when they are on COOL. So, COOL drys the air and makes it cold. DRY drys the air but warms it back up before sending it out the vents.
Jun 14, 2010 | LG LWHD2500ER Wall/Window Air Conditioner
Ice buildup in wall mounted unit
Icing on evaporator is caused by:
Dirty evaporator
Bad cold control
Low charge
Low ambient air temp
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 25, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Whirlpool heating/air window/wall unit-ground wire cut off
Normally that is connected to the unit in the casing and also to the ground that is part of the plug that goes into the outlet.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 12, 2009 | Whirlpool ACE114PP Heat Cool Wall Room Air...
Not blowing cold air
Sounds to me like your compressor is not operating, first check the filter to make sure its not pluged up, if thats not it, you will need a qualified service tech to come a diagnos it for you, but sounds to me like the compressor is bad, hope that helps
Jan 20, 2009 | Heating & Cooling
Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Whirlpool Designer ACU109PR Thru-Wall/Window Air Conditioner Logo
212 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Norman Al-Anbar
Donni Steen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
