The tv comes on and shuts off for about 10 or 15 sec the cable box stays on but the picture shuts down and comes back on in about 10 or 15 sec
Your power supply is going bad
Posted on Aug 26, 2008
Samsung TV no sound no picture backlight on and off
Check voltage at the power board. After 120 volts enter the TV, there is fuse then a small high voltage transformer, then a 100 uf rated at 450 volts capacitor. There should be 390 volts DC at the capacitor. Without this 390 volts the TV will shut down.
Dec 28, 2017 | Samsung Televison & Video
Diagnosing tv auto shut down.
The TCON board is not junk, if anything it is the mainboard that is faulty.
Jul 04, 2016 | Proscan 40LD45Q TV
Why does green light stay on when picture is shut off with cable remote from cable box
You need to "pair" your cable remote to your tv. The proceedure will vary with cable supplier. Comcast remotes come with a paper listing codes to put in. Metronet has the following: Press and hold setup until led light blinks twice. press a mode key tv dvd aux. press and hold ok key until the device turns off. Other suppliers, your on your own.
Apr 23, 2014 | Mitsubishi LT-46153 LCD TV
My lg tv picture wont come on
After turning the equipment on try pressing guide or menu to see if that makes picture come on. if not try disconnecting and reconnecting the cable going from cable box to T. V.
Nov 10, 2013 | Televison & Video
The HDMI doesn't work properly
HI
The resolution is only set by the sending unit, in your case the cable box. You need to change this to at least 720P something the your TV can handle.
Now once you have down this, to try and solve your HDMI problem I suggest you do the following.
Switch-off your cable box and the TV set, unhook the HDMI cable.
Now reinsert it carefully to make sure it connects properly on both sides.
Now first switch on your TV and set the input to Video 6 ( your HDMI channel )
Now wait for 30 secs. Switching on your cable box.
Do not press anything and check if your picture now stays on without shut-down.
if the menu and other startup screens on the cable box is not flickering, but the normal picture you might have a HDMI conflict with your TV set.
O, you cannot change the input types.
Hope this helps!
Dec 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
May 27, 2009 | Samsung HLN617W 61" Rear Projection HDTV
TURNS ON OK THEN SHUTS DOWN, GREEN LIGHT STAYS ON
Mine does the same thing try a new lamp I am with what I have read this is the best solution. I have had green screen two fans replaced and now this. The picture was great but with all the problems i would never but a sony product ever again for anyone out there you should tell them sony sucks and send them to this web site for clues. Good luck.
Dec 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
The TV and Cable box both continue to shut down; Please Help!!!
Do you mean that the TV shuts off and the cable box also shuts off? Is the TV plugged into the back of the cable box? This sounds to me as if the cable box is defective and the TV is plugged into the cable box instead of the power strip. To prove whether or not the cable box is defective, plug the cable directly into the TV, plug the TV directly into the wall outlet and watch one of the lower channels. If the TV acts up and shuts off, have the TV serviced. If the TV plays fine, replace the cable box.
Jul 02, 2007 | Daewoo DTQ-29S1FCN 27" TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
