Question about Casio Cassiopeia PA-2400W
Casio PA 2400W (part II)
I have an ibm pcmcia soundcard. Is it possible to get this to work in the 2400u? Will it hurt anything if I just plug it into the 2400U?
SOURCE: Casio PA 2400W
No, No, No I'm afraid. This thing can't hack it when it comes to the power required to download mp3 files. Maybe some /really/ lo-fi midi or such, but nothing plesant.
Posted on Jun 25, 2008
0 characters
1 Points
Pc doesnt see ipaq h6315
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Apr 19, 2008 | HP iPAQ h6315/h6365 Pocket PC
Instruction Manual
check out http://www.ia.nrcs.usda.gov/Technical/gis/pda.html go down the page to the cassioppeia 2400 section et lioa la (or some such stupid saying in french)
May 30, 2007 | Casio Cassiopeia PA-2400W
When charger is plugged, amber light blinks once and then nothing? E125 not working at all!
The Casio PDAs will quit charging very quickly if the battery is very, very discharged. If you continue to remove and re-insert the charger into the PDA's power socket, the recharging cycle will last longer and longer until finally the stupid thing will fully recharge its battery.
I have two Casio PDA's and three batteries that were recovered after a bit of tedious struggle to force the charging cycle to complete.
Jun 02, 2006 | Casio Cassiopeia E-125 Pocket PC
E-mail Does Not Synchronize To IBM Workpad When using Notes Client 6.0`
This issue was reported to Lotus software Quality Engineering, and has been addressed in EasySync Pro 4.2. Supporting Information: OBTAINING EASYSYNC PRO 4.2 If you are a Passport Advantage member, you can obtain EasySync Pro 4.2 through the Passport web site at the following URL: http://www.ibm.com/software/support/pa.html Otherwise, EasySync Pro 4.2 is available for purchase from the IBM web site at the following URL: http://www-306.ibm.com/software/info/ecatalog/ Should this URL not be available, you can go to the IBM web site, http://www.ibm.com, and choose the "Ready to buy" link. Related Documents: What Issues Have Been Addressed in EasySync Pro 4.2 and Where Can It Be Obtained? Document #: 197088 Related information What Issues Have Been Addressed in EasySync Pro 4.2 and Historical Number 196957
Sep 14, 2005 | IBM WorkPad c505
Sep 14, 2005 | IBM WorkPad c500
32-bit card bus PCMCIA
No. The MobilePro 900 PCMCIA slot only supports 16-bit PCMCIA (PC Card) cards.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Microdrive compatible?
The microdrive is compatable with anything that supports reading compact flash memory cards, because there is a common method of communication between flash and hard drives that use pcmcia or CF slots.
Sep 13, 2005 | Dell Axim X5 Pocket PC
MemoryCard problems on one CE 2
Hello, Check that you formatted it with FAT (not FAT32 or NTFS). If not, format it again with this file system (FAT). I think it will resolve the problem.
Sep 06, 2005 | Casio Cassiopeia PA-2400W
Casio PA 2400W
Sep 05, 2005 | Casio Cassiopeia PA-2400W
CASIO E-125 has no backlight
Pretty common problem, and is normally one of three possibilities: 1. Ribbon cable that connects the backlight daughterboard to the motherboard connector has gone bad, or contacts oxidized. 2. Daughterboard itself has gone bad... 3. Power problem or cpu problem not activating upon powerup. Not as likely. 4.The fluorescent tube itself may has blown. The cure: carefully disassemble your 125, clean the ribbon contacts on both ends of the tiny ribbon cable, be careful, it is very fragile. If that doesn't work, find someone who has a E125 and swap out ribbon cables and see that works, that will at least tell you if the cable is bad or not. If that doesn't work, swap out daughterboards. If that doesn't work, sell it for parts on EBay and buy a new one, because anything else will probably be too expensive.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Casio Cassiopeia PA-2400W Logo
32 people viewed this question
Top Casio PDAs Experts
k24674
Are you a Casio PDA Expert? Answer questions, earn points and help others
