On my PC when I scan for channels the screen goes blank and MS error report screen appears. Then send or don't send error. either one you get brought back to desktop screen. Happauge has closed
Apparently the drivers available on the Happauge install disk that you purchase are not the correct ones or are out of date.
Solution:- Visit the Happauge web site and stelect your TV tuner type and install latest.
Posted on Sep 06, 2008
Mitsubishi wd 52628 input issue, blue screen and input error
there are no analog channels, they are all digital now, be sure your antenna is facing proper direction before scanning for digital channels
Apr 20, 2013 | Mitsubishi WD-52628 52" Projection HDTV
Screen is completely black now. When I try to boot up sometimes it will but then a blue screen with lines on it comes up then it goes blank and can't get it back
Blue screen errors are mostly associated with RAM problem or software issues. You can try reseating the RAM or it might need to be replaced.
Jun 09, 2010 | HP Compaq Presario V2000 Notebook
How do I delete the error reporting to microsoft
if it is Showing ” Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience ” Click “Don’t Send ” and everything get closed ,This Window error Report generated by microsoft is sometimes create problems for you , it is suggested you to dont ever click Send Error Reports or ” Please tell Microsoft about this problem ” because it will send all yours computer details to Microsoft , and creating problems for its better to disable that error repor,so that such problem not arise in future,There are three methods to disable Microsoft error reporting.
  • To get rid of this MS Error Reporting, Right-click the My Computer icon on your desktop and choose Properties.
  • In the System Properties , go to the Advanced tab and click Error Reporting.
  • Select disable error reporting This will make any crashing program’s window simply close itself.
  • You could also click But Notify Me When Critical Errors Occur, but it might be even safer if you select Enable Error Reporting.
Inspite of this technique you can also disable error reporting via control panel as well as via editing registry . icon_smile.gif
Tags: Dont Send, Error Reports, Microsoft, Window Error
May 19, 2010 | Computers & Internet
I can't send a fax from my vista program with out printing out the fax first and sending it the old way, and that waste paper. in the xp or word 2003 I can go to the send in the file and the fax wizzard...
You need to go to printers and choose 'add a printer'. Under add printer, choose the printer called "MS FAX." That will install microsoft fax as a printer. Next, print your document by going to File, Print... (make sure it says "PRINT..." then you should see a selection screen, choose ms fax, and there you go. That should do it.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
If your on the laptop too long or try to play a movie the screen goes black and a blue screen warning a unexpected shutdown has been done to protect system what does that mean?
Reinsert the RAM. it also occurs for dust problem. Clean the whole system/laptop. Also take necessary steps for free space in c:/ don't load heavy softwares like games, etc...
Thanks Good luck
Aug 11, 2009 | HP Pavilion dv9000z Notebook
Scan not functioning. Provides NO ERRORS.
Unplug the power cable from the All-In-One when there is still power in the unit.
Also unplug the power cord from the wall outlet.
Leave the cable unplugged for atleast 1Min time.
And connect the cable directly to wall outlet with out any surg protector (if you have a different outlet try with that)
Then before connecting the cable to the All-In-One press and hold the # and no 9 button do not release the buttons untill it comes up with a mesage as reset (or if the screen goes blank then release the keys and turn the power on)
Then press the setup/menu button and then press the right arrow key till you see print reports> the press Ok and scroll to print test page and check if it is functioning properly.
Then try a color or Black copy and check.
Good Luck
Sep 12, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Oroblem relating to MS office XP professional
ur file must have been corrupted. uninstall the version of MS Office u have and reinstall it.
plz do comment and rate.
Aug 23, 2008 | Microsoft Windows XP Professional With...
Maxim 1160 (Thomson) 32" Widescreen CRT - no signal
Your going to need the original remote first. then go into the menu and do a channel search on it. if it goes through and finds no channels then the tuners bad. You could have that famous RCA on nboard tuner fault where alot of sheild grounds are bad. This is not a job for the layman. if you cannot get channels by doing a channel scan call out an rca or thompson repair person.
Sep 22, 2006 | Thomson 28VK25US TV
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
