Question about JVC Cybercam GR-D200US Mini DV Digital Camcorder
DV terminal question
What is the DV terminal?
    Master:
  • 473 Answers
This terminal allows for direct digital transfers to other equipment with DV input terminals, such as JVC's GV-DT1 multimedia printer or the video capture card in your computer. The same terminal when bi-directional ( in and out ) allows dubbing from another DV source.
Posted on Sep 05, 2005
My computer has USB Terminal, and my Canon Mini Digital Camcorder ZR60 has DV Terminal. How to connect ?
you have to buy and install IEEE1394 Firewire adapter to connect DV devices to your computer. Probably a cable too.
Oct 09, 2014 | Video Cameras
I need the driver in order to operate vvebcam mini dv d005. I got the driver on a CD, but during installation process a failore had happen and now I an geting the following message: "This application...
Hey there,
Use this installation file instead:
http://www.techmoan.com/files-drivers/MINI%20DV%20D005.zip
Unzip it using your favorite unziper (winzip or 7-zip) then run the executable file.
Jun 22, 2011 | Cameras
Our Canon XL2 has problem with Terminal DV and Terminal. The screw is loose inside. It's totally not work. CAn you fix it? We are in San Jose area, Can we have your phone number?
It's fairly easy to do there's a video on Vimeo on how to do it. I personally suggest you get a ground strap from fry's before attempting this fix. only 5 screws or so to disassemble the unit and I'd suggest you don't disconnect the 2 flex cables between both halves because they're a pain to align just right and you'll definitely pop a main fuse if not seated properly. The main fuse is about the size of a grain of sand and a pain to install.
http://vimeo.com/2760889
May 28, 2010 | Canon XL2 Mini DV Digital Camcorder
Where is the dv terminal on a insigia model d400 pc
The spec sheet for this computer is located at >>
http://insigniaproducts.com/products/computers/D400.html
Assuming that by "dv terminal" you are refering to a digital video output jack, your computer ( according to spec. ) was manufactured with analog video support only. The good news is that it will support a digital pci video card. Be careful though, video cards can be expensive, depending on capability.
Dec 08, 2009 | Computers & Internet
How do I download movie from my canon zr90 mini DV camcorder to my computer?
Transfer images effortlessly
The ZR90 expands video possibilities with a built-in slot for an SD (Secure Digital) Memory Card or a MultiMediaCard, in addition to the MiniDV cassette. That means you can easily transfer digital photos to your PC straight from the camcorder using the supplied USB cable or IEEE1394.
DV Terminal
The IEEE1394-compliant DV terminal also lets you connect the ZR90 to a DV-compatible computer or another Canon DV camcorder. That means you can easily transfer your digital movies to your computer's hard disk, edit your scenes, and then use them to create high impact Web sites, video e-mail, interactive CDs and DVDs, or a personal video album.
Nov 22, 2009 | Canon ZR90 Mini DV Digital Camcorder
Problem
Hi I don't really understand what are you asking here but check the manual. There is a s-video connection, i.Link (DV) connection and a regular A/V connection. btw the DV cable is not included with the camera.
Mar 22, 2006 | Sony Handycam DCR-TRV520 Digital Camcorder
DV terminal
Sep 14, 2005 | JVC GR-D70EK Mini DV Digital Camcorder
Connection using Firewire
Use a DV cable to connect the camcorder to the computer. Determine whether your computer has a 4-pin or a 6-pin DV terminal. Use an appropriate, commercially available DV cable for your computer's DV terminal. When making this connection, the use of the compact power adapter is recommended. How to connect ? 1. Turn the camcorder's POWER switch to . ? 2. Move the TAPE/CARD switch to . ? 3. Connect the computer's DV terminal and the camcorder's DV terminal with the DV cable as shown in the image below. The location of DV terminals differs between computers. For more information, please refer to the documentation that came with your computer. Important: 1. Operation may not work correctly depending on the software and the specifications/settings of your computer. 2. If the computer freezes while the camcorder is connected, disconnect and reconnect the DV cable. If the problem persists, do as follows. (1) Disconnect the DV cable, and then turn off the camcorder and the computer. (2) Turn the camcorder and the computer back on and reconnect them with the DV cable. 3. The image files saved on the hard disk drive of your computer are original data files. If you wish to edit these image files on your computer, make copies of them first, and use the copied file, retaining the original.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
64 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
