Question about JVC Cybercam GR-D200US Mini DV Digital Camcorder
Trpuble transferring from PC to camcorder
I am having trouble transferring from the PC back to the camcorder using the firewire (IEE1394, I-link and DV) connections, what's wrong?
    Master:
  • 473 Answers
Since the transfer of digital signal to the camcorder is fully automatic (no controls or adjustments of the process are active other then start or stop) the signal coming from the computer MUST be continuous. If any glitches or interruptions are present in the signal coming from the computer, the camcorder will automatically cancel the connection.
Posted on Sep 05, 2005
When i use the cable in my computer to get the pictures off they come off but my videos dont
Depending on your model, you might need to try and transfer the video via the firewire port. Lots of newer camcorders have a USB and a firewire (IEE1394). Typically, the USB is for photo transfers and the firewire/DV is for video transfers.
Hope this helps.
www.austintelstarservices.com
Jul 26, 2011 | Video Cameras
Is there a way I can transfer video to my computer?
You need a firewire (iee1394) cable to connect the camara to a computer and a editing software to transfer the video to the computer.
There are two tipe of firewire connectors: 6 and 4 pin (big or little) the camara has a little one, the board for desktop computer generally are big ones, meanwhile the notebooks generally have the little (4 pin). Look at your computer because is frustrating buy a cable and isn.t the correct one.
if the computer hasn't a firewire port you need a board (around 15- 20 €).
If the computer is a notebook there a PCMCIA firewire card (30-50 €) card.
If you use windows you have movie maker that is a very simple editing software but it works. You can find free or cheap editing software.
Feb 05, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
PC with Windows XP will not recognize DCR-HC96 Handycam, and I don't have the software disk that came with the camera. Help
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Windows XP Operating System only):
As you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
As you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video. The i.LINK port is also called IEEE 1394 or Firewire port.
An i.LINK is a black D shaped connector with 4 or 6 pins. The i.LINK cable is an optional accessory for the Camcorder. You require to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Firewire cable depending on the number of pins on the i.LINK / Firewire port of your Computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Good Luck!!!!!!!!!!!!
Sep 29, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Unable to transfer video information onto PC ACER ASPIRE using windows Vista for editing by windows movie maker. Interface on PC is via USB. If software driver for firewire or 1394 interface is available...
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Sep 28, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Your how can i load my footage to pc from sony DCR-HC52E via firewire
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE: You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!
Sep 26, 2009 | Sony DCR-HC52E Mini DV Camcorder
I woul like to put all my digicam recordings onto dvds
You should either download video to a computer (using firewire/IEE1394 connexion), then use a video editing software to build DVD films, or a direct firewire to DVD software (no editing, just dump the video on a disk). This is a bit difficult if you are not accustomed with computers, and takes some time if you want to have nice results. An over possibility is with new home DVD recorder / player, much have now a firewire/IEE1394 input that lets you download atomaicaly from your camcorder to a DVD or the internal Hard drive if the player is equiped with. This last seems to be the best for you if you just want to save your video for further visionning, and don't want to du "cut and paste job" that would be made possible with video editing soft on a computer. Then you should look for a home DVD recorder, and be sure to have it with a IEE1394-Firewire input. I hope this will help.
May 28, 2009 | Sony Handycam DCR-PC3 Mini DV Digital...
Help!! Can not connect my Sharp ViewCam Z VL-Z3U Through FireWire
Try searching these posts to see if they will help your problem. Seems this is common. See the link below.
http://www.fixya.com/tags/VL_Z3U
Mar 26, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Panasonic NV-GS30 firewire connection
you must a software that will make easy for you to capture like Adobe Premier or some other application that is applicable for firewire or IEE1394.
Dec 05, 2007 | Panasonic NV-GS30 Mini DV Digital...
Transferring from the PC back to the camcorder
Sep 14, 2005 | JVC GR-AXM25 Camcorder
JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
79 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
