Question about Sony STR-D965 Receiver
Sony str-d965 (protector)
When i turn on my reciever it will show the fm station then change to protector. what shall ido? what parts do i have to change?
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Sony str-d715 flasses protector
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
Ganx
  • 113 Answers
SOURCE: My sony str de605 am/fm reciever flashes
Hiya, not sure if i remember correctly but try reset it. First disconnect the speakers (make sure error isnt there)
When it is ON, press and hold the power button for about 4 seconds. It should then ask reset, clear or something and press enter. When its finished, try it again. If ok, reconnect speakers. If it happens with speakers, there is a problem. If it doesnt work and goes straight back to protect, then there is an internal fault (if i have the reset procedure correct)
Best of luck
Posted on Jul 16, 2009
dunnbiker
  • 8546 Answers
SOURCE: SERVICE MANUAL FOR sony model no str-d965
Register and download it at retrevo.com
Posted on Apr 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: sony STR-D965 display flashes protector. how do i
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Feb 25, 2011
Tune stations on the radio
Use this link to see how to set up and listen to AM/FM stations.
How to listen to FM and AM broadcasts
Dec 18, 2014 | Sony 7.2 Channel 4K Black A/V Receiver -...
How do i get my sony DA30ES am -fm reciever out of protector mode
Here is a guide for you: STR DA30ES Protect
let us know how , if you need further assistance.
Jun 09, 2012 | Sony STR-DA30ES Receiver
Sony STR-D965 display flashes protector. how do i fix?
Feb 25, 2011 | Sony STR-D965 Receiver
HI, WHEN I TURN UP THE VOLUME THE DISPLAY SAY'S PROTECTOR POWER OFF AND THEN IT WORKS TILL INCREASE THE VOLUME THEN IT COMES ON AGAIN. ARE THE SPEAKERS TOO SMALL??
disconnect all speakers and try volume on its own.Then try one speaker at a time and increase volume this will help you if one speaker is bad.If unit acts up no matter what you do ..Then theres a good chance you need to send it to a shop .Try to find one thats sony authorized..thanks
Aug 05, 2009 | Sony STR-D965 Receiver
Sony amplifier STR DA2000ES protector code 22
go to your manual and repeat connection and setup and try with new cables because may be the cat bite something hidden from your eyes.
Apr 10, 2009 | Audio Players & Recorders
DOES NOT PICK UP FM CHANNELS CLEARLY
Does the receiver work for AM? I need to isolate the problem circuit. Please try an AM station and update this.
Thanks,
Dan
Jul 29, 2008 | Sony STR-DG510 DTV Receiver
Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
May 15, 2008 | Audio Players & Recorders
Protector
It shows protector because the unit detects a short in the amp section of the unit. You will need to trouble shoot the amplifier section and replace the bad parts. If you have no solid state repair experience, my best advice would be to have a pro take a look at it for you. Good luck
Apr 10, 2008 | Sony STR-DE525
Manually tuning the reciever
you should be able to tune in manually.
press tune
press fm or am
press d. tuning
enter the frequency of the station 4 or 5 digits ie 9370 or 10450
another thing to look into would be getting a yagi fm antenna, they are directional and although you may have to rotate it for best results, they work great.
Nov 20, 2007 | Sony STR-DE985 Receiver
134 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
