Question about Casio Cassiopeia PA-2400W
Casio PA 2400W
I really like my 2400W, but there is one problem I have. It doesn't have an earphone jack or microphone jack. The microphone jack is not so important, but if it had an earphone jack, I could use it as an MP3 player and ditch my CD player. Does anyone know if it is possible to hook up an earphone to this PDA? There is a jack on the machine but the documentation taht came with it says that it is for some "special" purpose. The machine has a RS232 port. It would seem that it is possible to get sound from this port. Any ideas?
No, No, No I'm afraid. This thing can't hack it when it comes to the power required to download mp3 files. Maybe some /really/ lo-fi midi or such, but nothing plesant.
Posted on Jun 25, 2008
When i plug my external microphone into the 3.5mm jack it doesnt work
First you need to check that the microphone works by plugging it in something else. If that works, go to Control Panel - Sounds and check that the mixer unit has microphone enabled. If it is, then the socket is faulty.
Also make sure you are putting in the microphone socket and not the earphones or auxiliary in socket.
Oct 06, 2016 | Computers & Internet
Bought turtle beach z11 headset, cant get mic to work
The Z11 has a four-pole input/output plug to connect the mic and the earphone. The earphone needs to be connected to the earphone jack and the mic needs to be connected to the mic input jack on the back of the computer. In other words, you should have to 3.5 mm plugs. Plugging both into the same jack will disconnect one or the other. Check your adapter, It should have two separate 3.5mm plugs. If it does, be sure they are connected to the right jacks on the computer. The headphone jack will have a headphone symbol; the mic jack will have a microphone symbol. Go to System Preferences, Sound. Select the line in preference for input and the line out preference for headphones. Just may work.
Mar 14, 2014 | Apple iMac G5 Desktop
Can't get the headphone sound working from the laptop
The Laptop has 3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Hope this helps.
Dec 01, 2012 | Samsung Silver 13.3" Ultrabook...
Earphone jack doesn't seem to work
tried to hooked up with other earphone jack first, if still doesn't work check the earphone jack of the tv which may have loose contact joint in the board.
Oct 14, 2012 | ViewSonic Televison & Video
Hi i have a 1st gen 16gb ipod touch. When i insert the earphones into the socket i either get no sound, very poor quality sound, or ok quality sound which disapears when i move. i think this is because of...
Some devices such as yours have a 4 conductor jack, (used for earphones and microphone) and most earphones have a 3 conductor plug. They are not compatible. This would be my first guess. Second is earphones and earbuds get tossed around, put into pockets, etc. The cords can get damaged, and not be visible from the outside as the wires inside are very delicate. I would try a set that works in a different device.
Dec 02, 2017 | Apple iPod touch 1st Generation (8 GB) MP3...
Earphone microphone plug gmrs122. Which is the
the signal which goes to a main amplifier is tapped before a main amp, if main speakers are playing, than check the following.
i microphone using continuity using avo resistance
ii jack contacts, there is a change over springs on it.
if you can do it or take it to a w/shop
Mar 26, 2009 | Audiovox GMRS122CH 2-Way Radio
Connect 2.1 Logitech to a TV
if you have an RCA output for your audio. you can buy a lead that goes from 3.5mm headphone jack into 2 RCA phono plugs.
Feb 25, 2009 | Logitech X-530 Computer Speakers
Connect Logitech 2.1 to TV
i dont know how ur tv does not have a earphone jack i wonder now a days how they make such tv's , pls try to take sound from audio LR if it helps other wise no hope to get sound on speakers sorry pls try to find in manual if there is any hidden headphone jack some where see in manual
Instruction Manual
check out http://www.ia.nrcs.usda.gov/Technical/gis/pda.html go down the page to the cassioppeia 2400 section et lioa la (or some such stupid saying in french)
May 30, 2007 | Casio Cassiopeia PA-2400W
MemoryCard problems on one CE 2
Hello, Check that you formatted it with FAT (not FAT32 or NTFS). If not, format it again with this file system (FAT). I think it will resolve the problem.
Sep 06, 2005 | Casio Cassiopeia PA-2400W
Casio Cassiopeia PA-2400W Logo
112 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Computer Links
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
