Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer - broken cycle selection knob
When you pull out the cycle selection knob to start the cycle it pulls right out. There doesn't appear to be anything to keep it attached to the inside screw. Do I need a new knobe & screw?
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like you need both knob and screw!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Washer Knob broke
You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Start knob pulled out and won't go back in (spring loaded)knob came off
Check to see if any part of that knob looks broken.It may have a locking clip that you have to place on the knob first ,so that when you push it back on it locks on.The clip is very small and looks like its shapped like a U/or V
May 14, 2008 | Frigidaire ATF6000ES Front Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Mar 30, 2008 | Speed Queen AWS52NW Top Load Washer
Frigidaire Washer Model FWT449GFS1
needlenose pliers grabbing the center shaft (white plastic around a brass center around a screw), turned counterclockwise will free the remainder of the broken knob and allow you to remove it and then screw on the new part.
Mar 23, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Jun 17, 2007 | Kenmore 44042 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
102 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
