Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
Red Light/Blue Light I/O Error
My drive is set to Master and being read on a USB 1.0 slot on an XP machine. The drive appears in "My Computer" but when I click on it I get "I/O error". Also the NexxTech shows a solid red light. When it first starts up it is a blue light or a blue flickering light...but then a solid red light. Please advise.
  • margolch Aug 31, 2008
    I have the exact same issue...please help!
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Posted on Aug 31, 2008
XP rebooting again and again
Do you now have both hard drives plugged in? You must have the Master hard drive in the IDE1 slot and the second hard drive jumpered to cable select and put on the IDE2 slot. As you are looking at the cable from the open side of the computer, the IDE cable connected to the hard drive should have the red stripe towards you. The end of the ribbon cable should be plugged into the primary hard drive, with the second hard drive plugged into the second plug on the ribbon cable. On the hard drive there should be a diagram for how to jumper each hard drive for primary or cable select.
NOTE: You cannot put a hard drive into the computer and expect it to boot, even if it has an operating system on it. The OS must be installed onto the hard drive after being installed into the system.
Good Luck,
NOLA Tech
Jan 31, 2010 | Compaq Presario 5000 PC Desktop
Emachine ET1331G-03w Documentation
To install an IDE CD rom, you will need to open your computer and you will see an IDE Slot, your computer usually has two of them either directly next to each other or under each other, there is usually one white one and one blue one. IDE Slots look like this:
The white IDE Slot is usually for the Hard Disks and the blue IDE Slot id usually for the CD Roms.
The white IDE Slot is the Primary Slot and the blue is the secondary.
You will need an IDE cable to plug in to your blue IDE Slot then you will need to plug the cable in to your CD Rom and make sure that your CD Rom is set to run/work as the master. If your computer only has one IDE Slot or you do not have an extra IDE Cable you can plug the CD Rom in to the Primary IDE Slot with the Hard Disk assuming you are only using one Hard Disk.
If you are going to use the Primary IDE Slot you will need to make sure that your CD Rom is set to run/work as a slave and it must not be set as the master. The way to change it is by moving the pins at the back of the CD Rom, they are found at the back next to the place where you plug the IDE Cable in to or next to the power input. You will be able to tell if your CD Rom is set as a slave or as a master by checking the image on the top part of the CD Rom, this image will tell you how to set your CD Rom as a master or as a slave.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | E-Machines eMachines Desktop PC
Hard drive and/or jumper and/or data cable problem?
ok, Lets start by looking at the cable colors you are talking about. The drive doesn't care wether it is on secondary or Primary drive cable. As EIDE drive cables can support 2 drives each, 1 being a Master and the other being Slave. With no jumpers on the drive it should be set as Master. You can only have 1 Master drive on each channel or cable as you identified it. If you have set the drive to Cable Select and the Computer does not support this you will have problems. There should be a diagram on the top of the drive showing the different jumper settings. If not a computer store that sells parts should be willing to give you a cd that Seagate distributes that you can use to see the settings or teh Seagate website. They have used teh same jumper settings for years on EIDE drives regardless of how large they are. The only real limitation is going to be what the computer can see and use. If you are going to use that drive as a Master Drive on the Primary EIDE channel you will have to have and OS installed on it eventually as that will be the boot drive. The computer is not going to boot from a Slave drive without a third party boot loader which acts as the initial boot OS until you have selected teh OS you want to load.
Jan 02, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
I bought 2 Sandisk Cruiser 4GB and when I plugged both of them into the port that is designated on the computer neither one does anything. The red right flickers but keeps going out. I wiggle it and the...
best to buy a usb muti slot
some usb such as flash devise do have this prob
try diffrent slot ,
try plug usb leave in and restart computer
when back in windows it should at least say found new hardware
Aug 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Windows XP Blue Screen
change your ide cable or sata.
Reset your bios settings pull cmos cell from motherbord for minute so all settings are defaults.
Also boot your computer with winxp disk then if you able to enter in setup then go to recovery console mode and run "chkdsk /r' command .
Also check your harddisk is master set jumper in master position .
Aug 18, 2009 | Computers & Internet
I have brought a Western Digital Drive WD5000G032 home from the office with a lot of backup data that was transferred to it over ethernet. I am trying to copy it to my home server for additional security...
It's a usb drive no drivers are needed. It may be blown if it's not showing up when you plug it in. When you transferred the data, was it plugged into the usb port and showing up as the drive that was receiving the data. I would check the machine that you used to transfer the data from it may have transfered it to a different drive, as this portable would have had to have been selected in the computer receiving the download or it would have gone to the C drive by default, and may be sitting on that computers drive.
Jan 31, 2009 | Western Digital 500GB My Book World...
My dvd-rw can't read dvd but can read cd
1.Turn on the PC. When the HP/Compaq logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may different, F2 or Del)
2.Use the Left and Right Arrow keys to select Main.
3.The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
If the name for the drive exists, skip to Step 3. Otherwise, continue to the next step.
Step 2: Reseating cables
If a drive name does not appear for each drive and None is listed in the BIOS, use these steps to open the computer case and reseat the drive cables. Work on a hard flat surface over a non-carpeted floor.
1.Turn off the computer, unplug all cords from the PC, and then press the Power button on the front of the PC for five seconds.
2.Remove the side panel.
3.Remove both the IDE ribbon cable and the power cable from the back of the CD drive.
•If the drive name appears in the Primary IDE section or the hard drive name is now missing, the IDE cable is bad or the drive settings are wrong. Replace the IDE cable and connect it according to the drive jumper settings . That is, if the small rectangular connector (the jumper) on the drive is set to MS (Master), connect the master end of the IDE cable into the back of the drive. If the jumper is set to SL (Slave), use the slave connector on the cable. If the drive is set to CS (Cable Select), you can connect using either connector on the cable.
Step 3: Removing Drive in Device Manager
Remove the drive name from Device Manager:
4.Close the Properties window and select the CD drive name.
5.Click the Uninstall or Remove button (in Windows XP this is the square button with a red X).
6.Click Yes or OK to remove the CD listing. Do not restart the PC.
7.Close Device Manager.
8.If your PC has Windows XP, perform the next step to clear the registry filters without restarting the PC.
Clearing the registry filters in XP
Click Start, Run, and type the following into the Open field: regedit
Click OK. The registry editor appears.
In Windows XP, click File, Export, type a filename that is easy for you to remember, and click Save.
In Windows 2000, click Registry, Export Registry File, type a filename that's easy for you to remember, and click Save.
A copy of the registry has saved for back-up purposes.
Click the plus sign (+) next to the following items in the list:
•HKEY_LOCAL_MACHINE
•SYSTEM
•CurrentControlSet (or the current control set with lowest number if that is all that is listed)
•Control
•Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
Select LowerFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key.
May 18, 2008 | Computers & Internet
Computer doesn't see hd
hi, re: sabrent enclosure:
sort of same issues. documentation is feeble. hd powers up. red light is on.
but the new pc doesn't recognize the drive and, obvously doesn't assign a
drive letter to it.
i tried reversing the cable, changing the hard drive, using different usb port,
re-booting. still doesn't see the drive.
1. jumper settings are correct
2 i use vista, not win 2000 or xp
2 harddrive is old, from old computer
vista doesn't have 'my computer'
i can find manage disk management
can't right click becausse the drive isn't there
how do i change the hdd settings from dynamic to basic if i can't see the drive?
answers to your questions":
1. i'm running windows vista home
2 size of drive... it's old and probably fat(32) under 1g
3 i cycled through the settings
j8 jumper settings
slave, master, & single
no settings work
4. yes i heard the drive spin up
5 the led is red, not green
thx again for your efforts
ken bossewitch
kb@bossewitch.net
Dec 03, 2007 | Sabrent (USB-2535) (USB2535) IDE...
External USB drives not visible in OSX or XP
For the WD HDD, you need to set the jumper as Single or Master
For other HDD, you need to set as Master
Dec 21, 2006 | Macally 1 Bay (phr-100acb) Firewire/USB...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
1,229 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
