Question about Nokia N73 Cellular Phone
Nokia n73 problem
Hey!
i got a problem with my nokia n73 after i become failed to update it via nokia software updater ,it is off and not beciming on,
please help me in this problem
  • ayaz_wahcant Aug 27, 2008
    kindly can u tell me how it can be checked?
    President:
  • 1,952 Answers
Untill unless it will get disconnect before finish its update..it ll affect ur parent board of ur mob...so better check ur main board whether workin or not..after tat ll go for further
Posted on Aug 26, 2008
What's your problem?how to repair N73 Mobile Phone Startup Failed Contact Retailer with usb connected with desktop via internet
try to download latest pc suite and connect the device and update software, if problem persist then is need to be flashed on box by some oficial repairer
Jun 23, 2012 | Nokia Cell Phones
I would like to update Nokia n73 music edition software. May i know the procedure. Thanks in advance.
Hi
For updating your firmaware of Nokia N73
You need to Download The following tools
  1. Nokia Pc Suite
  2. Nokia Software Updater
or else Nokia Ovi Suite
But i Will say the methods using Nokia software Updater
  • Download Nokia pc suite from
http://www.softpedia.com/progDownload/Nokia-PC-Suite-Download-11999.html
  • And Nokia software updater From
http://www.softpedia.com/progDownload/Nokia-Software-Updater-Download-141287.html
Install Nokia pc suite then Nokia software updater
It will ask for your PC to restart
Continue ,then Select Nokia software updater .
Connect your phone
It will Find out the connected phone
Before Proceeding further: A Word of CAUTION:
  • Your phone will be useless when updating failed in the Middle of updating due to System Restarts or Internet Connectin Failure or Cable Disconnection
  • So consider in mind that
U Need
  • An UN interrupted internet connection
  • Do not disconnect the Data cable after full installation of new firmware
  • Computer shall not restart or shutdown while updating
(If any of this failed the phone cannot be recovered )
So method continues.....
after Nokia software updater finds your phone, it will check for new firmware avail for your phone or not ,
\if avail select download and install
Keep in mind the Above words of caution
An advice is that If You feel not good ,then better give it yor nearest Nokia Service centre ,they will install a new firmware for your phone
Hope this will Help You........
May 13, 2010 | Nokia N73 Music Edition Smartphone
Trying to update phone operating system but comes bake failed
Please tell me what steps and programs you are using. It should be something like this:
Install Latest version of Nokia PC Suite
Install Nokia Software updater
Connect your phone to computer via DKU-2 cable
once Nokia pc suite confirms that your hone is connected then run the Nokia software updater and it should do the rest.
If you need your data from the phone back it up 1st using the PC suite
Mar 14, 2009 | Nokia N73 Cellular Phone
N73 Software update 4.0839.42.2.1 failed
remove the cable and before update make a backup then download the nokia software updater from here
http://europe.nokia.com/get-support-and-software/download-software/device-software-update# then wait about 15 minutes thats what the softare tells after that your phone is updated if
Dec 21, 2008 | Nokia N73 Cellular Phone
How to flash nokia N73
you can flash your N73 by using the normal data cable also but your cell must be in working condition for that ...
if your cell is in working condition then you do that by following these below given steps :
1. make a back up of all your data in cell and remove memory card ..
2. download the "nokia software updater " from the nokia website. below is the website given for you:
http://www.nokia.co.in/A4767968
3.install that and keep connected to internet it will automatically download and flashes and installs the new firmware for your cell .
remember dont disconnect or switch off the pc or remove battery while the process is going this may severely damage your cell and it may become unrepairable ....
if your phone is not working presently means then you can buy a DKU series cable which allows you to flash the phone,reset any codes,etc ...
if you dont like to buy then you can just visit some service center and get the cell flashed ... as you are also from india it may cost you some just 200 or 300 rs that s it ...
thank you
regards
-Dileep
rate my solution
Nov 13, 2008 | Nokia N73 Cellular Phone
N73 is out of work
Hello Lindsey,
Try to format your mobile if it doesnt work completely..The code for format is *#7370# ...IF your not able to connect to your Pc alone Then try to Uninstall the Nokia PC suite software and reinstall it again in you PC,it will help you surely...Thank you...
Jul 26, 2008 | Nokia N73 Cellular Phone
My N73 is off
try again using same process (Regards Paljor Lama)
My N73 is off
when the software updating process is happening the PC must not be turned off.. if this happens then there is a possibility of the phone software getting corrupt.
think that has happened to your mobile also.. take it to nokia priority show room and reinstall the phone software.
Hello,help me,please.I was updating my n73 Music Edition via Nokia Software Updater,when my PC stopped working.Then,I held my mobile,but I found it turned off by itself.I need your help,please
It won't turn back on huh lindsey? The same thing happened to my n73 while I was updating it. During the update process, it's formatting the entire phone operating software and replacing it with a new one. If the process is interrupted when it hasn't completed yet, it won't turn on anymore. What I did was get my phone reformatted by a technician I knew in the mall. This was in Philippines, so you should ask around where you can get your phone reprogrammed. Let me know how it goes.
Nokia N73 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
