Question about Amana ARB2217CSR Bottom Freezer Refrigerator
Bracket holding glass over fruit / veg compartment broke
The bracket at the back left hand side of the fridge that holds the glass tray over the fruit and vegetable compartment has broken. I don't know what part number it is. At the moment, my fruit/veg basket is carrying alot of the weight of everything that is sitting on the glass shelf. Anybody know what part number it is and how I can get a new one?
Http://www.partselect.com/Schematics/Maytag/54436.gif Maybe this diagram will help you. www.partselect.com I just replaced the Crisper Shelf Frame. I received it very quickly. I am now looking for some sort of support for the whole shelf, because it still seems to be sagging. I may have to invent something. If anyone out there has a solution, please post it.
Posted on Aug 12, 2009
Westinghouse refrigerator leaking , dripping water and accumulates near bottom at fruit n veg basket. Some time it also forms ice layer on glass of basket. Any solution?
You have a clogged defrost drain tube, beneath the freezer evaporator (remove the back wall of the freezer compartment) there is a drip tray with a hole in it, the hole leads to the defrost drain tube- take a turkey baster and flush the drain with warm water until you hear it pour into the pan beneath the machine... Help Me Find My Model Number
Dec 11, 2016 | Westinghouse Refrigerators
Wat temp is for fridge and freezer to be on plz
What are your recommended temperatures for the fridge-freezers? The default and recommended temperatures for our fridge-freezers are as follows:-
4?c for the fridge compartment, 5?c specifically for the fruit and veg compartment, and -20?c for the freezer.
The ideal temperature setting for a refrigerator is 3?C and for a freezer it's -18?C. The only exceptions are fridge-freezers in the RB*** range, for which we recommend -19°C (as -18?C isn't an available option for these models).
Keep your fridge at the perfect temp with these handy tips
Dec 04, 2016 | Refrigerators
Condensation on the fridge
The veggie draw should be able to control the moisture with the sliding lever on it.
Do you leave your food uncovered while it gets to room temperature? if not that may be your problem sealing it before it does.
Oct 26, 2015 | Bosch B26FT70SNS VitaFresh Refrigerator...
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
Gallery. How do I lower the temp in food section?
Should be 2 thermostats in the unit in back or on side. One for freezer & one for fridge. Turn it down to preference.
Aug 01, 2015 | Frigidaire Refrigerators
Will not make ice
I have a Samsung RF265AABP model. I had the same problem on several occasions. One time the problem was a broken temperature sensor wire on the ice maker. The sensor assembly often gets snagged on the ice tray or scoop or something and falls down, making it more likely to snag, and prevents the ice maker from cycling when frozen. It is quite easy to remove the ice maker once you get the drawer removed from the slides. It is held in place by two plastic clips located near the back of the slides. Pop the clips out, and then lift the drawer out. Pull the front plastic cover off the ice maker, then remove the two screws holding it to the top of the freezer compartment. Slide the icemaker assembly forward about 1/2 inch and it will drop down. Unplug the wiring connector and the ice maker assembly will drop right out. The temperature sensor is located in a flexible rubber like unit that holds the sensor against the plastic water tray. This whole assembly often falls out, and may be found mixed in with the ice.
I fabricated an aluminum bracket from angle stock to hold the temperature sensor assembly in place, and used a small tie wrap to hold the wire to the bracket, up and out of the way after soldering the broken wire of course. The tie wrap is not shown in the photos below. I drilled and countersunk two holes for the 4-40 screws holding the aluminum bracket. The temperature sensor is not shown in the photo, but the wire comes out the right side and crosses over to the left in front of the aluminum bracket.
Aluminum bracket holding sensor in place.
Ice maker assembly showing screws holding it to freezer. It is upside down in this photo.
Sep 23, 2013 | Samsung RS2630SH Side by Side Refrigerator
Water in veggie crisper and meat tray, Moisture build up on glass shelfs
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | Whirlpool Refrigerators
54409 // water accumulates under veg and fruit drawers?
Look inside at the back to see if there is a collecting troff which collectes the water runing down the cool plate. In the middle of the troff is a run off hole which takes the water outside to the back to an evaporation tray. if this hole gets blocked it floods the fridge and you know the rest. Some fridges have a looped plug which you pull out of the troff hole to clear the blockage. I know this as my fridge does this too.
Jul 26, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Feb 23, 2009 | Cuisinart TOB-50 Toaster Oven with...
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Amana ARB2217CSR Bottom Freezer Refrigerator Logo
224 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
