Question about RCA F35673MB 35" TV
Mind of its own
I have read some of the other problems of rca f35673mb and I think I have the craziest problem. I was awaked by the tv playing.This crazy tv turns its self on the it goes to channel 3 which it what the tv should always stay on (I'm on satellite) and channel 69.If you leave the tv unpluged for a couple of months tv works fine for a couple of months.Next door the people have the same problem(same year tv)And service man replaced (what they called a control panel)It's the board with the front buttons on.Can't find a control panel anywhere's.Is this the problem and what else could it be called.trinalynn12@yahoo.com
If you press MENU often enough, you will find and AUTOMATIC TURN ON FEATURE, also called ALARM feature. You can set it to Disable and this should cure your problem. You can also set times when it turns on automatically.
Does this help?
Posted on Nov 26, 2008
My tv wont pick up cable signle?
Possible bad tuner in the set if rear inputs function well.
Dec 17, 2012 | RCA F35673MB 35" TV
Will any universal remote work on my rca f35673mb tv?
Hello
Jusy buy one Philips Universla Remote control. RCA is listed in its codes list. The model number is [PHILIPS CL 034]. Codes and proceedings are given.
0704 0002 0406 0007 0011
................. 0611 0811 0312 0514 0720
................. 0102 0502 0601 0817 0917
................. 0835 0901 0103 0803 0211
................. 0912 0114 0519 0320 0420
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
OK.
Jan 04, 2011 | RCA F35673MB 35" TV
Humming noise when turned on. no picture. is there a reset button
There is no reset for this kind of problem. The chances are that the flyback transformet is shorting, horizontal output transistor is bad, or possibly bad power supply board. The unit will have to be opened up and troubleshot. Some RCA units seem to be prone to this problem, and a friend of mine paid $300 twice within 6 months, so I can't vouch for RCA's long term reliability.
Hope this helps.
Oct 26, 2010 | RCA F35673MB 35" TV
RCA F35673MB won't turn on and makes a high pitch sound
The Horizontal Output transister is shorted and may have been caused by a bad flyback.
Feb 26, 2009 | RCA F35673MB 35" TV
The picture is drawn in from the sides
this problem we cal vertical fault..cause by capasitor is not in good condition at vertical area or loose solder at the vertical ic
Dec 08, 2008 | RCA F35673MB 35" TV
Rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Nov 09, 2008 | RCA F35673MB 35" TV
Not getting any channels on my tv
get digital channels but no analog
Mar 18, 2008 | RCA F35673MB 35" TV
High Pitched Sound
I have the same problem!! If you find out how to fix it, please let me know...
Jan 11, 2008 | RCA F35673MB 35" TV
Picture fuzzy and flickers (like tracking)
The flicker could be caused by a bad solder connection arcing or even a bad picture tube. If you notice the screen getting drawed in from the sides as well as top and bottom it may be in the power supply regulation circuits, but the focustat around the area of the high voltage transformer could also be breaking down. If it's over about 8 years old, I would replace it with a HDTV set. Check out the latest issue of Consumer reports for ideas. (No I don't work for them-I've just seen so many people just walk into a *Mart and pick out a TV like they were choosing a box of cerial without doing a bit of research to find one that would suit them best, that I'm trying to put out a word to the wise among us).
Feb 04, 2007 | RCA F35673MB 35" TV
Televison & Video Logo
66 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
