Question about Kenmore 46462 Front Load Washer
F20 Error code
My washer is hardly filling up with water, then it runs for a bit but stops. Error code F20 is showing. Any idea on how to fix this?
  • mygirlscout Aug 27, 2008
    Thanks, it's working great now!
I'm getting the same F20 error code. I bought this machine used and luckily it still has a warranty. Right now we only have the cold water hooked up, but the clothes don't feel very wet and the softner is still in the softner holder.
What do I need to do to correct it.
Posted on Aug 31, 2008
    Genius:
  • 1,028 Answers
Be sure to ck fill hoses make sure both are turned on all the way ..remove hose at washer end ckd screen inside inlet for sand/rust/gunk pull screen out to clean and be sure to reinstall it or you're asking for trouble down the road..also ck faucet end just in case someone installed one there 2..by the way just having cold water only on will cause same problem
Posted on Aug 27, 2008
F20 error code on maytag epic any idea what this means?
F20 means that the unit isn't detecting water is entering the machine quick enough. When the error code appears if there is little to no water in the tub, then you have an issue with either the water supply to the washing machine or the electronic water valve. If the washing machine fills up about 1/2 way up the door and is overfilling with the water, it means that your pressure switch is faulty and will need to be replaced because it's not detecting that water is entering the machine.
Mar 02, 2015 | Maytag EPICz 3.7 cu. ft. Washer
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
Code f 20 what does that mean and how can I fix it.
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
Before doing any of these fixes first ask yourself if you have over loaded the machine. Too many Bulky - heavy items will cause this same message.
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.zTyr5Yy1.dpuf
Oct 16, 2014 | Whirlpool duet Washing Machines
Got a f20 code on my washer and i have a question
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.FHzIAYn8.dpuf
Oct 05, 2014 | Whirlpool duet Washing Machines
How do I fix F20 code
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.2RAhsfLg.dpuf
Sep 19, 2014 | Whirlpool duet Washing Machines
I am having trouble with my washer. It is showing the F28 error code and then when I get that fixed, it shows the F20 error code. Can you please tell me what to do to get it running again. Thanks
F20 I believe is low water flow. On the intake fitting on the back of the machine where the hot and cold hose hook up there is a fine screen inside the fitting on the machine. My cold water screen was clogged from stuff in old pipes. Cleaned it and no more e F20
Feb 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Kenmore 46462 Front Load Washer Logo
349 people viewed this question
Sal De
fordexpert
Robert Rankin
