Question about Dishwashers
When I close the door(latch) to the dishwasher it sounds like the pump is coming on. When I open it it stops and so on and so on. The washer works but to turn the pump off the door needs to be unlatched
  • 1,031 Answers
Posted on Aug 26, 2008
  • Starnley Johnwells
    Starnley Johnwells Aug 27, 2008
    dont forget to rate the solution as fixya!!!
Maytag mdb6759aws3
check with a volt meter if you are getting power to the machine where the wire hooks up to the washer. it that's ok then I would check the door latch if it is not closing like it should you may have a problem with the latch switch. I had an whirlpool that happen to and I replace the latch and it worked with no more problem
May 26, 2014 | Whirlpool 24 in. DU900PCD Built-in...
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
The door on my machine won't shut?
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
My dishwasher no longer cleans my dishes and white spots remain even when jet dry is being used.
Dishwashers rely upon water circulation. Make sure there is nothing blocking the pump receiver at the bottom of the washer, like paper labels from gars, or large food pieces. It also relies upon the proper amount of water in the washer. After the washer fills and starts its cycle, squeeze the handle to open the door but do not open the door until all the sound has stopped. The water level should be visible and close to the top edge of the basin. Don't worry, opening the door after the pump has stopped will not spill water on the floor. If the water level is good and you are sure there is nothing blocking the pump receiver, check the stem in the center of the basket.
Sep 20, 2010 | Dishwashers
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. And, if the door latch will not engage the dishwasher will sense it as open door and will not start the cycle. And the sound might be coming from the door lock solenoid (a hum/buzz sound).
The light also blinks when the dishwasher detects a no-fill condition. You’ll need to get access to the fill valve by removing left panel, look at back to see where valve is when you get to it remove one of the wires and set meter to ohms setting and put a lead on each tag on valve. The reading you should be about 3.6k ohm if you don’t get a reading then the valve is at fault. I'll also suggest you to check the detergent dispenser solenoid for this issue. Remove the door panel and see if there is a round item at the dispenser assembly with two wires attached to it. Put the dishwasher into a cycle and when the noise appears, gently press on the solenoid to see if that is where the noise is coming from.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Mar 30, 2010 | Whirlpool DU943PWK - Multiple Color...
When washing dishes the dish washer leaks water? lots of water
it sounds to me like you need to check the seals underneath the dishwasher.
Oct 16, 2009 | Dishwashers
I own a Kitchen Aid KUD102frss dishwasher. The door is not closing properly. It appears to be the latch. The start button blinks
you might have started a cycle and opened the door by mistake.  try pressing HI TEMP, AIR DRY, HI TEMP, AIR DRY close door to latch, press cancel.
it worked with mine.  you can give it a try.
Aug 20, 2008 | KitchenAid Dishwashers
Cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out back.
Oct 15, 2006 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
