Question about Intel Motherboard
W4682 desktop none of the usb ports are recognizing anything. i had the power supply changed but it didn't come from an emachine it came from a dell. the old power suppy went out on me but before it did the usb ports were working fine. please help!!!
  • Anonymous Dec 02, 2008
    I have the same problem , my friends W4682 Emachine has no working USB ports , when you plug a device in it freezes , and this is also after a power supply replacement.
    Will a bios flash solve this and where to download ?
  • Intel Master
  • 3,051 Answers
You will need to boot into bios and in the periphial device or advanced area it should show the usb devices make sure that they are enabled and not enabled and make sure that the plug and play devices are enabled ok i hope that this is helpful best regards mike
Posted on Aug 28, 2008
I added a 4 port usb card to a dell e520. The
try updating the drivers to the card to see what happens. another solution is try it on another computer. if the same problem exists on another computer you could have a bad card.
Mar 30, 2010 | Dell Dimension E520 PC Desktop
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
Why do the usb ports not recognize anything i
Did you put in the drivers for the Motherboard Chipset? There is a Northbridge and Southbridge chipset which control USB and many other functions. Does device manager give any indication as to USB being attached?
Oct 10, 2009 | E-Machines Emachine T5026 power supply **...
I have Emachine 2002 model W4682 problem with all
You should have gotton a cd with the orginal drivers with you machine. They may also be hidden on you machine.
Remember that the maker of your machine is gateway. I suggest calling them if you have no luck with the emachine division. The company called Acer is the parent company of all of them. That should help. Emachine is not the bst cmpany outthere when it comes to customer service. What is not working correct on your machne??
Oct 09, 2009 | E-Machines eMachines Desktop PC
Sandisk cruzer not recognized on dell deminsion 3000
Had the exact same problem. turned out that it has some kind of defect, i pulled it apart and messed with it for about an hour then just threw it in the trash and bought a Kingmax flash drive. there isnt much you can do with flash memory in terms of repairing it.
Sep 21, 2009 | Computers & Internet
New Dell desktop can't recognize external hard drive
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 28, 2009 | Dell Computers & Internet
I have a Emachines w4682 and the monitor was showing no signal when I turned computer on. I hooked up a different monitor and that one worked so I re connected the original monitor and it worked I then got...
Possible reasons are bad power switch, bad power supply, bad motherboard, bad memory , device card is not seated properly. Suggest replace power cord to see if still no power, also you may want to remove cover and make sure all your memory and device cards are seated corrrectly. If you get a amber light at the power button, bad motherboard is likely cause
Mar 24, 2009 | E-Machines eMachines Desktop PC
USB problem with Dell Dim. 4600
1.have you use other usb device also same ?????? try plug in rear port usb also same????
2.try to use you original dell cd to preloaded OS. to see usb can recognizing.if still can't may be you usb port faulty need to change motherborad
Jan 02, 2009 | Dell Dimension 4600 PC Desktop
Usb 2.0 ports not working on my emachines T3504
You may need to uninstall your current usb's and let Windows redetect them.
click on START, SETTINGS, CONTROL PANEL, SYSTEM. Click on tab HARDWARE, click on DEVICE MANAGER. Scroll down to UNIVERSAL SERIAL BUS CONTROLLER. Delete everything there. Click on ACTION, SCAN FOR HARDWARE CHANGES. It should redetect and you should be good.
Jul 24, 2008 | E-Machines eMachines Desktop PC
Intel Motherboard Logo
71 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
