Question about JVC Cybercam GR-D200US Mini DV Digital Camcorder
Can I manually control the zoom and focus? - JVC Cybercam GR-D200US Mini DV Digital Camcorder
    Master:
  • 473 Answers
Yes. Zoom can be controlled either by a variable speed rocker control, or a zoom ring on the lens. Focus is either automatic or manual via a focus ring.
Posted on Sep 05, 2005
SOURCE:
I have a haninex 800 dlsinstdual 8 I can load it but do not know the controls to zoom,focus,etc
If this has a motorized zoom and focus then it will be on the remote listed as zoom and focus or on the hard buttons on the projector itself. If you don't have this feature then you must focus and zoom manually on the lens itself. There will be two tabs or rollers that you make these adjustments with this.
Feb 15, 2015 | Office Equipment & Supplies
Why does my lens only zoom to 200
Could be, because most camera's only can auto focus till f/1:5.6. And if 5.6 is reached at the focal length of 200 mm, the camera stops it from going to a part it can't be focused.
Perhaps you try the lens in manual focus, and manual zoom.
Jan 28, 2014 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
Lack of focus at 20" on zoom
Zoomed fully in, the minimum focus is about 20 inches. If you want to focus closer, you must zoom out. See page 72 of this manual.
Nov 23, 2010 | Samsung S850 Digital Camera
I need a manual for AF 35-70mm f2.8 D zoom nikkor - no idea how to use this lens.
i was not able to find a manual - this review may help http://www.kenrockwell.com/nikon/3570.htm
The lens consists of
  1. Zoom
  2. Focus
  3. Aperture
  4. Macro
1) Zoom - this is by push pull - so you push the lens out to wide angle 2) To switch to manual focus - will need to be done on the camera and then you can use the front control ring to focus - 4) also you can use the button to switch to macro mode - BUT only with the Zoom at 35mm - lens fully extended 3) You have an aperture range of 2.8 - 22 this varies the amount of light allowed into the lens - 2.8 is the most light - F4 to F5.6 to F8 - each change halfs the light allowed in - so changing from F4 to F5.6 half the light
Mar 29, 2010 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Jan 26, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
Repair lens PDX10
It sounds like the optics in the lens are no longer calibrated. It needs to be looked at by a professional.
Oct 10, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Manual Focus
1) Press and Hold the FOCUS button until to you "MF" appear in the lower left corner of the LCD Display on the back of the camera. Then you can release the Focus button. 2) Press and Hold the DISP/i button to see the Manual Focus Range. 3) While holding the DISP/i button, use the Tele/Wide Zoom Key to set the desired Manual Focus. You can see the focus change as you toggle the zoom key. 4) When you are ready, release the DISP/i button and Press the Shutter Button to take your picture. *Press the Focus Button to return to Auto Focus / Macro options
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Manual focus
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
129 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
