160gb maxtor hard drive installed, recognised in bios and windows xp device manager but not shown in 'my computer" does it need formatting if so how do i format a drive with no drive letter
Try Going to START, CONTROL PANEL, ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, DISK MANAGEMENT from here you should be able to see the DRIVE and format if needed.
Posted on Aug 26, 2008
My maxtor one touch external is not being recognized by my pc. how can i solve my problem?
If you mean that Manager cannot recognise it but you can see it in My Computer, and if you have the Manager setup etc. progs saved, then try uninstalling Manager and reinstall it. If that does not work you could try Seatools or formatting the drive by right clicking it to get the option in My Computer. Regards Chas
Dec 11, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
I changed my windows to vista and then i tried to re-install my maxtor one Touch 4 mini 250 GB but the computer can not recognize it, so plz tell me what is the steps to re-install thx
By 'install' I think you mean install Maxtor Manager, but perhaps you have files which were saved by 'drag-and-drop' with the previous OS. These might be recovered the same way, even in Vista, if you can open the OneTouch from Control Panel. To use Manager with the OneTouch which had stuff saved via Manager with a different OS, you could first try to recover the files with Manager installed on another PC using the old OS version. Then format the OneTouch through Control Panel in Vista and with luck Manager will recognise it. If it does not, and you can see the drive in My Computer, then uninstall Manager (which might be corrupt) and try re-installing it. Regards Chas
Nov 28, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
I installed a Maxtor 4R080L0 as a slave drive. My Windows Explorer (XP) cannot "see" the drive. - It is recognized by the BIOS. - It is properly listed in the Device Manager and 'running properly' - Win...
You will need to go into the control panel, administrator, and then disk drive manager. once there you will need to initialize the new drive and then format the drive before the system will see it. Format using the NTFS file system only if you are using XP, After the format is completed reboot the system and your new slave drive should show up just fine and you will be able to log into it or use explorer to view it.
Apr 14, 2017 | Maxtor QuickView (4r080l0-qv) 80 GB Hard...
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Maxtor 3200 160gb usb hard drive not in my computer
Is it showing up in your USB system tray icon as a device?
Go to the Computer Management interface from the Administrative Tools. In there is a Disk Management node. See if the disk drive shows up there. Maybe it is listed without a drive letter and you need to supply one in order to see it in "My Computer".
Also, has the drive shown up properly before and is just suddenly not showing? Or is this the first time you're trying to use it? When you connected it to the USB port, did a little tooltip window appear and say it located a new hard drive? It should then install the right driver and notify you that it is ready for use. There is a chance you might need an updated device driver...
Dec 24, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
I have just bought a WD external hard drive (250GB). i plug it in via USB (2.0) and my computer will not auto install the device. i have no software with the product. help!
If you are running Windows ME, or Windows 2000, or Windows NT, or Windows XP or Windows Vista you do not need any drivers, Windows will detect any USB devices provided the USB device does not draw more power that the USB port can provide.
Your Maxtor external drive shoud have a power adapter connected to it before you insert it into the USB port.
If the Maxtor drive has not been partitioned and formated then you cannot use or see it until you do so.
Your manual should give you instructions to do so.
Basically you need to go into the Control Panel, then Administrative Tools, Then Computer Management, then Disk Management to create a partition and format the drive in NTFS file format if you are using Windows NT, XP or Vista.
Nov 26, 2008 | Western Digital Passport WDXML800UE...
Hooked up my PC with 2nd Hard disk, a MAXTOR 6L 160 MO Hard drive , but Windows XP SP2 does not recognise it, i.e it does not appear in MY computer. However it is recognised by the Device Manager in...
try open computeradministration.
go down to disk handling. If you can see it there you can format the disk and what way get it to be shown.
CS.
May 20, 2008 | Computers & Internet
Drive Shredded
Open Administrative tools, Computer management applet; under storage, disk management. You will probably need to partition and reformat. If this drive is used only on XP machines, then format NTFS, otherwise FAT32.
Sep 18, 2007 | LaCie (300740) 160 GB Hard Drive
HDD not recognized in XP Installation
if you are using it as a slave hard drive, you should be able to right click my computer, manage, then in next window double click storage, then disk management, then look for your drive, you can then look to see if its recognised, if not it will tell you that its not configured, and you should be able to right click on it and format it.
Jun 07, 2007 | Maxtor DiamondMax 10 300 GB Hard Drive
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
