Question about JVC Cybercam GR-D200US Mini DV Digital Camcorder
Can I manually control the audio level?
Or is it always automatic?
    Master:
  • 473 Answers
No. The audio level is always automatic via an AGC circuit.
Posted on Sep 05, 2005
SOURCE:
Connect optimus lab 1100 to macbook
The type of computer is not relevant. This turntable provides output at nominal "line level" and can be connected to your MacBook with a properly shielded audio cable through the audio input.
For best results, you might want to disable automatic-gain-control (AGC) in the "Sound" preferences pane in the "System Preferences" panel, and set the level manually such that the input does not overload.
As I mentioned above, the signal level is nominally "line level", and that can mean very different things depending on context. You might find that using a passive volume control (potentiometer) between the turntable and the computer's analog-to-digital converter can greatly improve the quality of sound.
Jun 20, 2014 | Apple MacBook Pro Laptop Computer with...
Intel 82801EB ICH5 - AC'97 Audio Controller [A-2/A-3] PCI downloads
Hello, you can try the drivers from these sites:
http://realtek-hd-audio-drivers-xp.en.softonic.com/
http://www.nodevice.com/driver/company/RealTek.html
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
But there is always the manufactures homepage to download from.
Good luck with your seach.
May 03, 2012 | Intel Computers & Internet
Everything lights up and is working,but i have no sound
Do you accidentally have it muted? The Mute button, located on PASSPORT's top panel and SmartCord. Have you turned up the volume on it? Volume Control (VOL) To increase or decrease the audio volume, press and hold the (+) or (-) volume control buttons located on the top case. A sample alert tone will be generated, along with a corresponding bar-graph on the display. Once you have reached your desired volume level, simply release the button. This level will be stored in memory. In Preferences Auto Volume is the default. This feature will increase the audio alert level automatically when the ambient noise in the vehicle is high. Good luck.
Mar 06, 2011 | Passport 9500i Radar/Laser Detector
Having problem getting htr 6295 to see subwoofer---what level do i set at? + or - db and at what level?---thanks for help
It's automatic or subjective.
Page 20. If you use the optimizer automatically, it's set for you.
http://www.retrevo.com/support/Yamaha-HTR-6280-Receivers-manual/id/23605bh845/t/2/
On page 58, you can do it 'by ear'. Then it's up to you to decide.
Feb 06, 2011 | Yamaha HTR6280 72 Channels Receiver
Ihave a 32 inch sylvania tv that I bought from sears about 5 years ago. there are audio out rca jacks on the back of the set. I tried hooking up a surround sound system and I got no sound out of these...
Usually those terminals are always on, and the only thing that you can change about them in the menu is audio out fixed(always same level) or variable(level controlled via remote). There might also be a speakers off option in the menu,try it and in your case it might be the switch between internal and external sound. And in the last resort look at the back for a manual switch, otherwise check for faulty cables. You also might have a problem with the set.
Hope this will help. Good luck
Dec 01, 2009 | Televison & Video
My Marantz PMD 661 digtial audio recorder is flashing ALC on the display and I can't find what that means in the book. Any idea?
ALC Automatic Level Control
In other words, an audio compressor which reduces the level when the level gets too much.
Look up "audio compression" with Google for a complete treatise how it works.
Oct 28, 2009 | Marantz Audio Players & Recorders
My DirectTV HD remote won't let me control my Yamaha HTR-5960 receiver. Know any codes that might work?
No it can't be done. The input level is automatically controled to give a fixed output at a predetermined level..........................sodeep
May 04, 2009 | Audio Players & Recorders
Commercials come on and volume is louder than tv shows
Volume and video levels for live broadcast, as well as satellite feeds are preset at a master control panel prior to broadcasting. TV commercials are pre-recored via satellite feeds, on seperate equipment, where audio and video levels are set manually by a technician. These manually set levels are very difficult to match, since the levels on the master control panel change. When the master control technician switches control to mark, a robot, mark loads the commercial and it is broadcasted, hence the different audio levels.
Mar 15, 2009 | Philips Televison & Video
Stick shift # Automatic RPM
That is normal,If you do the same speed in 4th gear the rpm's will almost double.
The rpm's will repond faster in a manual than an automatic.
In a manual the engine supplies the power required directly to the gear that you have selected thus the engine rpm's will increase or decrease as needed.
Jan 07, 2009 | 2002 Nissan Altima
Using headphones with Logitech X-230 speakers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
24 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
