Your PC should not crash from this issue. Your PC motherboard has a small (usually watch size) battery on it that provides power for the clock, and basic I/O settings, such as boot options, disk drives etc... The battery is pretty easy to replace, just open the case and you will see the battery held in a little socket. Make sure to turn PC off and properly ground yourself by using a static wrist band or leaning one arm over the power supply while taking the battery out. Take the battery and go to your local RadioShack, The Source, London Drugs etc.. and show them the battery. It should be a pretty common battery such as a CR2032 or CR2025 etc..
Once you replace the battery go into the BIOS by pressing F2, ESC, or DEL (which ever command shows on your screen for Bios Setup, System setup etc).. Change the clock to read the current time and exit, saving changes. You should not get this error for a long time as these batteries last much like a watch would.
If you don't change the battery, it won't crash your PC, but will eventually annoy you enough to replace it :)
Regards,
Chris
>>type slmgr.vbs -ipk on command prompt(Administrator)
>>reboot computer
>>as computer comes back up windows activation page comes up
>>activate by phone
>>dial the number
>>obtain new product key
>>as you log on to desktop
>>notification regarding Win7 OS Not Genuine is gone
>>windows is now activated
comments suggestion ratings and violent reactions will greatly be appreciated
