Question about Kenmore Elite 45986 Front Load Washer
Foul smell coming from washer
Every once in a while, my washer starts to smell horribly. I have cleaned out the detergent/softener cups and underneath, and also the gasket around the door. Is there another area that needs to be cleaned periodically? I have run empty loads with bleach in all the dispensers, and it seems to help for a bit, but I don't think it is taking care of the actual problem. PLEASE HELP!!
  • vickiroberts Aug 26, 2008
    Thanks for the suggestion-I will certainly give it a try! It just bugs me that I can't find what the source of the smell is!! :(
Run a vinegar wash periodically. My mother has an upright that was doing the same thing and all the repair man told us was to not use powder detergent, clean the gasket, and do the vinegar washes periodically.
Posted on Aug 26, 2008
WHY IS THERE A BUILD UP OF SLIME / MOULD ON DOOR SEAL. HAVE TO KEEP SCUBBING OFF.
How to Remove Mold and Mildew from Front Load Washing Machines Today...
How to Remove Mold and Mildew from Front-Load Washing Machines
moldy-smell-washing-machine-1.jpg Front-load washing machines are notorious for collecting mold.
I've had my front-loading washing machine for about four years, and it has some great advantages - it's quiet, fast, uses less water and detergent, and gently tumbles (rather than yanking) my clothes. In general, I've been so pleased with it that I was shocked one day when I opened the door and was nearly knocked unconscious by a fetid blast of moldy-smelling air!
How could a machine that's so wonderful, suddenly turn so horribly smelly?
Gaskets hold moisture.
The answer is in the way the machine is designed. Front-loading washing machines have watertight, airtight doors that seal with a rubber gasket. That rubber seal traps moisture in the machine and also provides the perfect nooks and crannies for mold and mildew to grow.
Top-loading washing machines, on the other hand, have a rather loose fitting metal door that easily allows the tank to dry out between loads.
The problem isn't helped by our laundry preferences. High sudsing detergents and liquid fabric softeners leave behind residues and films that invite mold growth. Cold-water cycles and mild, eco-friendly detergents don't quite blast away residues like their environmentally-unfriendly counterparts.
So, to keep mold at bay, front-load washers need just a bit more maintenance than top-loading machines.
How to Get Rid of Mold and Smells in Top-Load Washers
If you've got a stinky front-load washing machine, here's how to get it smelling fresh again:
    moldy-smell-washing-machine-3.jpg Cleaning gasket on washer.
  • Clean Gasket: Use a rag or towel to clean the rubber door gasket on a front-loading washer with either hot soapy water or a spritz of mildew cleaner. Make sure to wipe underneath and around it as well. Be prepared for some slime and gunk, and possibly a stray sock or two!
  • Clean Dispensers: Remove the detergent dispensers and give them a good scrubbing. If they don't come out, clean them as best you can, using a bottle or pipe cleaner to reach back into the crevices.
  • Run Cleaning Cycle: Next, run an empty wash cycle on the longest, hottest water setting (or a tub-cleaning cycle, if you have it). Add one of the following directly to the wash tub:
    • 1 cup of bleach.
    • 1 cup of baking soda.
    • 1/2 cup of powdered enzymatic dishwasher detergent (such asCascade Complete).
    • A commercial residue-busting washer cleaner (such as Affresh orSmelly Washer).
    moldy-smell-washing-machine-4.jpg Commercial cleaning pellets.
  • Repeat Cleaning Cycle: If the problem persists, repeat the cleaning cycle and consider trying a different additive. It might take several cycles to get the smell out.
  • Professional Help: If you've tried every way to clean your front-load washer and it still smells, you may have mold growing back behind the drum, or possibly a clogged drain or filter. A qualified repair person can dismantle the machine and clean it for you, or you can unplug the machine and carefully explore and clean it yourself.
Preventative Maintenance
Once your machine is clean, follow these tips to keep it that way:
    moldy-smell-washing-machine-5.jpg Allow washer tub to dry.
  • Air It Out: If possible, leave the door of the front-load washer cracked open to allow it to dry thoroughly between cycles. However, you shouldn't do this if you have children or pets who could be tempted to climb (and possibly become trapped) inside the machine.
  • Remove Loads Promptly: Be sure to remove wet clothes as soon as the cycle is finished. Set your washer to beep when it's done, so you don't forget.
  • Choose Detergent Wisely: Choose low-sudsing detergents specifically made for high-efficiency (HE) machines. When possible, choose powder over liquid; liquid detergents are usually higher in suds.
  • moldy-smell-washing-machine-6.jpg Clean washer dispensers.
  • Use Less Detergent: Read the labels and use no more than the amount recommended for each load. Experiment with using less detergent, until you find the minimum amount necessary (sometimes just a spoonful) to get your clothes clean.
  • Avoid Fabric Softener: Liquid fabric softeners leave residue that contributes to mold in front-load washers. Instead, use dryer sheets or dryer balls to soften your clothes.
  • Dry Gaskets: Use an old towel to wipe around and underneath the door gaskets and the inside of the door on front-loading washers. Ideally, you should so this after every cycle, but at the very least it needs a periodic wipe down to remove any water or mildew trapped in the folds.
  • Use Bleach: About once a month, run a hot water bleach cycle. I usually take the opportunity to throw in work towels, fabric shower curtains, and muddy gardening clothes, along with that nasty gasket-cleaning towel.
Good Luck
Feb 27, 2015 | Washing Machines
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Horrible smell coming from the washing machine
Have you cleaned the filter in the washing machine?
Mar 31, 2009 | AEG 24 in. Favorit 40660i Built-in...
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Odor
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Dec 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Smelly washing machine
Oct 10, 2008 | Kenmore 24832 Top Load Washer
My washmachine smells horrible. My whole house it starting to smell like it. What do I do??
there is nothing in a washer to smell - just stainless steel, rubber and plastics!
check the following:
are you using liquid detergent? if so after extended use, the machine smells like drains. put on the hottest wash with no clothes and smell will go. revert to using powder.
check there is a water barrier between the drain hose and your main drain. if not, the smell of your sewer will come up thro the drain hose.
is the drain connected to a spigot off the sink trap and do you have a waste disposal unit? these stink and unless you again have a water barrier the smell will come thro the drain hose
Jul 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Smell coming from washing machine
Apr 18, 2008 | Hotpoint WMM39 Front Load Washer
Constant smell and now displays rl
A solution from the internet:
Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda.
It should clean the machine and move out the bad smell.
Another:
I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution.
MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts.
They are not very cheap but they work great --
I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain.
YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health!
I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine
Dec 17, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
124 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
