Question about JVC Cybercam GR-D200US Mini DV Digital Camcorder
How can I play back a tape produced on the GRHD1U?
Can I use a DV VCR? Can I use any other type of deck?
    Master:
  • 473 Answers
Tapes may be played back by the camera itself. If the tape was shot in the 720P (HD) or 480P (SD) modes, it cannot be played back on a standard DV VCR or camera. Tapes shot in the 480i (DV) mode are completely compatible and can be played back on any DV VCR/camera. In addition, tapes can be dubbed to a JVC HD DVHS VCR via the firewire connector.
Posted on Sep 05, 2005
SOURCE:
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Feb 25, 2014 | Panasonic AG-DV1000 Mini DV VCR
Have a Sony HVR M25U deck and put in a mini-dv tape and the tape played fine but not able to play, ffwd, rwd or stop. So I unplugged power cord on deck. Plugged power cord back in and now the tape is...
DO NOT , UNPLUG THE POWER CHORD, DO ONE THING SWITCH ON THE VTR AND THEN HAVE AN ALL PIN .. THEN RESET THE MACHINE ... WITH THAT PIN .. AND THEN PRESS EJECT ... YOUR TAPE WILL COME OUT ..
Jul 14, 2011 | Sony HVR-M25U HDV VCR
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Tape format playback for AJ-D250
menu item 107 can be used to select dv playback
Dec 08, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Deck will not accept DV tape
most likely problem is a defective cassette housing. I've replaced about a dozen of these in AG-DV2500s.
Jan 12, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
Is there lp playback?
no - only sp tapes. if you try an lp tape, it plays for about 2 seconds, then the deck ejects it.
Nov 28, 2007 | Panasonic AG-DV2500 DV/Mini DV VCR
JVC HR-DVS3U -- time code issue
I Have the same problem. It will cost me $350.00 plus tax to fix.
Aug 24, 2007 | JVC HR-DVS3 Mini DV/S-VHS VCR
Video won't show up on comp monitor
check your inputs on that machine. there are settings that you need to do. when you put a tape in the minidv, does it play fine? if it does, you need to check your input setting on that machine..good luck
Apr 03, 2007 | Panasonic AG-DV2000 Mini DV VCR
Tapes not in 24p play for 2 seconds than stop, WHY?
The BR-DV3000 DV deck has LP inhibit function which is set in the operations menu. JVC does not recommend the use of LP mode and therefore locks this mode out by default. You can change this setting to allow operation in LP mode if you like but I don't recommend it. Using LP mode on DV tape causes the error rate to escalate due to the narrower track width produced by the slow moving tape. Good Luck, this is a nice machine! Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | JVC BR-DV3000U DV/Mini DV VCR
JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
109 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
