Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Printer keeps pausing itself!!
I finally got the UI to work, but every time I try to print the ir3300 pauses itself. I click "resume" and the queue pauses. I resume the queue and the printer pauses.
Mac OSX, PS v1.40
  • 1 more comment
  • PESysMan Sep 03, 2008
    Printer apparently requires a "printer" board. Although it has an ethernet connection, an IP address, I can ping, and the remote UI works just fine; actual printing over the network apparently requires additional hardware.
  • galexandr Jan 14, 2009
    hey, how are you? i have the SAME EXACT PROBLEM.
    i have ir3300, and cant seem to get it working,
    i need help. if u dont mind.
  • dev_24ind Mar 31, 2009
    hi iam canon ir3300 printer. when iam giving print the print is being cancelled by itself. i cannot able to solve this problem is ther any solution for this problem. i am using parallel port from computer to my canon ir 3300. can i try for a lan port ?
    Sniper:
  • 89 Answers
Dev_24ind: The parallel port cannot be used for printing by default. Heaps of people have made this mistake. You need a N Boot Rom installed and N system software. Almost certainly you don't.
Get a Network Multi PDL Printer Kit C1 for IR3300 (contains N Boot Rom and NIC aka ethernet port). A technician can install this and update system software and you will be able to print. You will be able to print over a network (which is the preffered option) use Remote User Interface and Pull Scan using Canon Network ScanGear (google it).
Posted on Jul 18, 2009
  • mdgm Jul 18, 2009
    PESysMan you do not require a printer board. Whoever told you this is wrong. You need a NIC (preferably as printing over network is better than over parallel) a N Boot Rom installed and the copier to be upgraded to N firmware. Sounds like your copier has not been upgrade properly.
    Go into service mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. BOOT-ROM should have a N at the end. If it didn't you probably would be getting an error when trying to use the copier. PS/PCL is probably blank. If it is, it means that the firmware for printing has not been loaded onto the copier. Get a technician to come out and reload N firmware.
What does it mean when printer says it's "on pause"
Exactly that. Either something was taking too long to initialise or you inadvertently clicked the Pause button. You can change by clicking the Print Queue icon in bottom right or screen and click 'Resume'.
Feb 02, 2017 | PRINTER Office Equipment & Supplies
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
HP 1020 black white printer not commencing printing. Looks like paper pickup is not working. Computer connection is fine, etc. startup noise when I turn on printer also OK. Just refuses to start jobs in...
Dear Sir,
According to your problem it seems to be your printer paused,to resume this go to settings>then printer and faxes>confirm your printer status as ready,if it is paused right click on printer icon then cliak on resume.
If you had any problem post a feed back we were happy to assist you,
Have a nice day
Sep 17, 2009 | Office Equipment & Supplies
I'm unable to delete a job from the queue. And therefore, I'm unable to print anything else. Any ideas of what to do? Thank you!
Open the print Queue, click the print job that is hanging and then from the menu, I believe under file, click pause. Once it is paused tried to delete the print job.
Sep 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
HOW WILL I UNPAUSED MY PRINTER?
There should be a printer icon in the notification area. You can double-click on that to bring up the printer status. If the icon is not there, you can go to Start -> Control Panel -> Printers and double-click on your printer. The first item in the print queue should be listed as paused. Right-clock on it and select Resume from the context menu.
Jul 10, 2009 | HP Office Equipment & Supplies
By UI do you mean RUI (Remote User Interface)? Have you installed a network kit? If so did you upgrade firmware using SST? If not, you need to do this or printing won't work.
In service mode. Copier > Display > Version > PS/PCL there needs to be a number e.g. 30.06. If there is no number the copier does not have any print drivers on it and won't be able to print. You also need to have a N BOOT-ROM (included in network kit). There Should be a N next to the number for BOOT-ROM under Copier > Display > Version if a N BOOT-ROM is installed.
Jan 14, 2009 | HP LaserJet 3330 All-In-One Printer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
5,130 people viewed this question
old marine
old marine
