Question about Brother MFC 7420 All-In-One Laser Printer
RESET DRUM I DO NOT KNOW HOW TO RESET THE DRUM LIFE ON A Brother MFC-7420 All-In-One Laser Printer
    Sniper:
  • 56 Answers
Open the front door where you put the toner/drum unit in the machine. Press options then press 1.
Close the door.
Counter reset!
Posted on Jan 15, 2009
  • 5 Answers
1. Press the Clear key to display drum status.
2. Press 1 on the telephone keypad.
3. When the display shows "ACCEPTED", close the front cover.
Posted on Dec 10, 2009
4 Suggested Answers
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
timeattack
SOURCE: Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Press 1 to reset the drum count
Close the over
Posted on Feb 06, 2009
SOURCE: how to reset drum counter for brother hl4070cdw laser printer
When you replace the drum unit with a new one, you need to reset the drum counter by completing the following steps:
  1. Turn the printer power switch back on.
  2. Press the + or - button to choose "Machine Info".
  3. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  4. Press OK, and then press the + button to choose "Drum Unit".
  5. Press OK two times.
Posted on Aug 29, 2009
How do i fix a brother mfc-7420. when it says toners life has ended. we have tried to put new toner and drum in it. with no help. we need to clear the message
check the paperwork that came with the drum unit. Usually there is a sequence you need to follow to clear the drum message such as starting the printer with the front door open. These instructions are shipped with a new drum when you buy an orignal brother drum. If you puchased a refurbished or 3rd party drum you need to talk to your vendor as they should supply these instructions.
Jun 23, 2015 | Brother MFC-7420 Laser Printer
Brother MFC-7420; "Take Drum out; Slide blue tab..."
go online type in Brother MFC-7420 reset and follow details
Jan 30, 2013 | Brother MFC 7420 All-In-One Laser Printer
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 change drum soon light, did, still says change drum soon, how do I rest the drum, I cannot find my manual. Tks
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 05, 2010 | Brother MFC-7420 Printer
Cleaning blade did not work
error code c00f0401 of my hp officejet v40 printer
Jan 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Dec 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother Printer won't accept mostly full toner cartridge
On the side of the cartridge (TN2000) there is a white reset flag, this need to set to twevle 'o' clock, thats towards the black roller. If that hasn't been reset the cartridge will register as low.
Jun 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
Drum on Brother MFC-7420
Why does the message "CHANGE DRUM SOON" continue to appear on the LCD display of my Brother machine, after I replaced the drum? Description: This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below. Open the front cover. Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO". Press 1 to reset the drum count. Close the front cover.
Jul 27, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
5,060 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
