Question about Rainbow E series Canister Wet/Dry Vacuum
Motor filter replacement
After removing the four screws, I don't see anymore screws! How do I get the motor out? My Rainbow is the newer e series.
  • Rainbow Expert
  • 324 Answers
If you are talking about the motor cooling filter round filter like this here then you must have removed wrong screws. Screws that you want to remove are hidden under clear lenses on the sides of the unit. You will need a screwdriver to remove the lenses (2 latches at the top of each lens). Once you have removed lenses you will see screws (4 or 6 - depending on the e-series model). Remove them and you will have the access to the filter.
Good Luck
Posted on Nov 01, 2008
What would happen if I would take out both hepa filters from my rainbow e-series? I do need extra super filtering - previous versions didn't have it and it was ok... Hepa filters are not so expensive...
It won't hurt anything if you don't have a problem with the tiny particles that will be blown into the air. The Hepa filters trap small particles that can be unhealthy to breath. Most of these particles consist of human skin and hair, pet dander, dust mites, etc.. Many people are not bothered by these tiny particles. Others, like asthmatics, can have serious complications from them and the Hepa filters really help.
Nov 24, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Don´t know how to take my Rainbow apart.
Your model is a bit newer than mine, but on mine, I have to peel off the foam rubber gasket that seals the canister to the top of the vac when you put it together. You will have to replace this gasket once you peel it off. Under the gasket are the screws that hold the top cover on.
Hopefully your model is similar to mine, and this is the answer you need!
Nov 06, 2009 | Rainbow E series Canister Wet/Dry Vacuum
How to remove an old Rainbow E Series Cooling Filter
The motor filter is under the top cover.
Caution: Be sure your vacuum is unplugged from the electrical outlet before proceeding! There are 2 screws on each side of the top cover of the Rainbow ‘E’ series vacuum cleaners located behind the decals. To get to the screws; use a non-scratching tool such as a plastic putty knife and pry out a corner of the plastic window, carefully pull out the plastic window and decal and remove the 2 screws. Repeat this process for both windows and then just lift up the top cover to expose the inside.
Oct 25, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow stops shortly after starting to vacuum
There is a thermal fuse on the motor field that sometimes fails. Sometimes the fuse does what it is supposed to do - prevents motor from overheating.
Causes:
a) Improperly worn motor brushes
b) bad motor bearings (that usually leads to uneven motor brush wear)
c) very dirty cooling air filter
To access filter and the motor - use small flat screwdriver to remove clear side panels. You will see 4 or 6 Phillips screws. Remove screws - cap will come off.
Good Luck,
Rocky
Mar 17, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Changing the two HEPA filters in the Rainbow E Series.
Plastic thing is fine. it probably has "e" in the middle...
To replace the motor filter you would have to remove cap. You have to get clear plastic lenses off the unit (you will need small flat screwdriver to release latches on the top of the lenses). Under those you will find a total of 4 or 6 screws. They hold the cap onto the main body. Filter is under the cap. See HERE if you need the filter.
Good Luck
Aug 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Jul 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Cleaning the flter on a e series rainbow vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=749568
Cleaning the filter on a e series rainbow vacuum
Posted by jonesjpc on Jul 06, 2008
This one does not have the tabs to depress as but has two screws in that area still doesn’t see how to get to the filter. Also I need instructions to replace power cord; On the E series single speed.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Rainbow E Series there really is no actual filter – the water is the filter for this particular vacuum. Before you remove the separator under the motor, place a newspaper or towel under the Rainbow without the water pan under the vacuum and then turn it on for a short period of time and spin the water moisture out of the motor and separator; then some of the maintenance is to remove the separator under the motor and clean that and then replace it. As far as replacing the cord there are screws under the Rainbow that need removal and then you can get to the end of the cord for replacement. The easiest way is to mark your wires and the cord will be much easier to replace otherwise check the owner’s manual for cord replacement or check with your local vacuum cleaner dealer in your area or to cal the cust serv @ the Rainbow factory for questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Changing the filter in Rainbow e series
Some of the e-series has a corrugated filter in the top section. To get to it, remove the clear plastic panels that are the sides. Most have 3 screws on each side to move, then the top half will come loose. There also is filter on the back, there is a door to remove to get to it.
Jun 03, 2008 | Rainbow 75th Anniversary Canister Vacuum
Remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
Jan 04, 2008 | Vacuums
Rainbow E Series Suction Problem
Being an E series some have a corrgated filter in the top, there is also a filter on the back. Could be a motor problem, not turning as fast as it should, in which case you will have to replace the motor. You might check, some had a 10 year warranty on the motor. If you are the original owner and only have had it 5 years, then it may be covered.
Sep 30, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
140 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
