Question about HP Photosmart 8250 InkJet Printer
Photos print too redish; blues are purplish
I started using non-name brand ink cartridges. The colors were fine for a while, but now seem to always have too much red/pink/blue-ishness. Is it the quality of the ink, or some other problem?
  • 4 more comments
  • cindybear4 Aug 27, 2008
    I guess I should have added, I went back to name brand, did the 'Clean Printheads' thing, and still have the problem. Ideas?
    Yes, it is HP (Photosmart 8250) and I replaced all the color and black cartridges with HP. Is there something else I can do to fix it?
    Thank you.
  • cindybear4 Aug 28, 2008
    Problem still not solved.
    I did switch back to all HP cartridges, ran the printheads cleaner--still pinkish/purplish photos.
    Sorry to be a pain, but this didn't work either! The blues come out purple, the light pinks come out magenta. Have I ruined the printer?
  • cindybear4 Sep 02, 2008
    I appreciate all your suggestions. Guess I'll have to take it somewhere and have it looked at.
    Thank you!
    Master:
  • 521 Answers
Oh its a problem many people face and get confused with.
nothing to worry.get ur printer settings back to the normal from photo .ur printer is st up for photoprintng on a photo glosy paper.this wrong setting is making ur printer print those dark unwanted colours.changing the setting will solve ur problem definately
Posted on Aug 28, 2008
  • HP Master
  • 1,183 Answers
Its a known issue ,after using the non branded ink cartridges, The printer can cause problems.
You can check two things
1. If you are printing photos , try changing the photopaper you are using.
2. Print the Hp test page , if the test page is faulty too, its time to get a new printer .
Thanks
proton
  • HP Master
  • 19,396 Answers
You need to clean printhead and printer carriage sensor contact manually, using cotton and printer cleaning solution.
  • 2,071 Answers
Photo Prints Slowly on HP Advanced Photo Paper
... 8250, 8250xi and 8250v Printers - Photo Prints Slowly on HP Advanced ... Prints Slowly on HP Advanced Photo Paper - c00564372 ... 8250, 8250xi, and 8250v printers print a photo on HP Advanced Photo Paper slower than expected. The ... Photos print  too redish; blues are purplish - s.gif » Choose the Best Ink Cartridges for Your Printing Task
Choose the optimum combination of ink cartridges to enhance photo quality. s.gif » Printing Photos from a Memory Card
... to view, select, enhance, and print photos. You can also print camera-selected photos, photos you ... in the Main tray or Photo tray. Check the Photo tray light to verify that ... Load photo paper. Check the Photo » Problems Printing from the Photo Tray
Instructions and troubleshooting on photo tray printing issues.
  • LORETO LACARON
    LORETO LACARON Aug 28, 2008
    SOLUTION:
    To solve the problem, open the Printer Properties and manually select the HP Advanced Photo Paper by following the steps below:
    1. From your application, click File , Print , and then click Properties .
    2. Click the Paper/Quality tab.
    3. In the Size is window, select the size of your HP Advanced Photo Paper.
    4. In the Type is window, select HP Advanced Photo Paper.
    5. In the Source is window, select the tray loaded with HP Advanced Photo Paper.
    6. Click OK to close the Printer Properties.
    7. Make sure HP Advanced Photo Paper is loaded in the printer in the selected tray (Main tray or Photo Tray) and click OK on the Print menu.
    Hope this may help;
    Regards,
    VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 29, 2008
    Check the cartridge compatibility for the appropriate product in the following places:
    • Cartridge compatibility charts for each product type:
    • In the product documentation: Look up ordering print cartridges or check the back cover of the manual that came with the product.
    • In the printer toolbox on the computer (only if HP printer drivers are installed)
    • On the cartridge package
  • HP Master
  • 1,879 Answers
FYI - the printheads of HP printers are actually comes with the cartridges.
If its not your computer or application, it is the printers logic board that is messing up your colors.
Try another computer / application.
You can, if you can find an identical printer to yours, test those new carts.
Posted on Aug 27, 2008
    Genius:
  • 2,035 Answers
Yes this is the color issue as you told this not brand of the printer and the ink quality depends upon the manufacture in this case you cart have dark blend of ink which is creating this problem ,try this but you need to use the original company cart in order to get the best colour results on the print:TRy this and make print
Print the image using a higher quality setting by following the instructions below.
  1. From the application you are printing from, click Print , and then Properties . The Print Properties screen opens.
  3. Select Maximum dpi or Best .
  4. Click OK .
  5. Good luck...
  • 1 more comment
  • Anand Kumar
    Anand Kumar Aug 28, 2008
    Your ink cartridges stay in the maintenance station when not in use.
    Depending on the printer model, the maintenance station may be located
    on the right or left side of the printer. NOTE: You do not need to remove the cover in order to access the maintenance station.
    To access the wiper for cleaning purposes:
    1. Unplug the power cord from the back of the printer.
    2. Move the ink cartridge carrier to the left by gripping the top
      of the rubber carrier belt and gently pulling it across towards the
      right-hand side of the printer.
    3. Take a warm, damp paper towel or napkin and gently clean the wiper on the right-hand side of the maintenance station.
    4. Then try to print...
  • Anand Kumar
  • Anand Kumar
    and then try to print..
  • 594 Answers
The problem is because you are not using h.p. cartridges.
it will do this until you get h.p. for some reason h.p is like that. i just had this problem a few days ago and contact h.p and that what they told me. and after i changed them the printer worled like it was supposed to.
  • 10,594 Answers
Please check settings of printer driver software. You might be set it on high color or high contrast like that.
  • HP Master
  • 6,487 Answers
Yes, because not all generic cartridges are compatible with all printers , because it will only work for a few times then after that you will start having this kind of problem, that why is not recommended to use a generic ink. if your printer is HP get a cartridges from HP also to make sure everything will be working fine....
Hope that helps........
  • Mark Gil
    Mark Gil Aug 27, 2008
    Try again to clean the nozzle and print head with the printer utility , and also check the alignment of the print head....
  • Mark Gil
    Mark Gil Aug 28, 2008
    If that's the case this can be a problem with the printhead itself thatmay needa replacemnet already since you still have this problem and all the cleaning is already been done...
    Guru:
  • 1,894 Answers
Always use the original inks.
if so there wont be any problems like this
also clean the nozzles.
  • 1 more comment
  • dewan nafees ahmed Aug 28, 2008
    not the print heads.
    did you clean the nozzle?
    that would help you a lot.
    am sure
    also one more thing.
    while installing there will be a small piece of plastic cover over the nozzles.
    we need not peel it off. but it would be better if you peel it off fully. first 2 prints will be smudging. after that you will be getting a nice print
    keep us posted about the improvements.
    thank you
How can I use non-epson ink cartridges in the Epson printer?
Yes and No. Non branded ink cartridges need to be properly programed to work correctly. If you are going to buy non branded, make sure you can trust the seller. Research the seller and you should be ok. Branded is always the best but also always more expensive and non branded always comes with a degree of risk.
Dec 03, 2015 | Epson RX595 Photo All-In-One Printer
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
I cant print photos on a paper they look faded when i print them and when i print a leter or words it prints really well, the printer is a canon pixma mp130...do you know what the problem might be ?
my canon mp250 won't print color photos it does well with BW but not color. I took back the first one I had did the same thing now the second one won't print color photos off the internet. what did I do wrong? Both inks are brand new.
Jan 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson R1900 Printer
ESP9 color prints begin coming out purple like
Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
Jan 02, 2010 | Office Equipment & Supplies
All of our photos end with a magenta to purplish hue. We are using Canon inks, and followed standard trouble-shooting procedures; checked proper placement, printer alignment, deep cleaning. We are also...
Print a "test" page:
<HTML><BODY>
<FONT COLOR="#FF0000"> RED TEXT </FONT><HR>
<FONT COLOR="#00FF00"> GREEN TEXT </FONT><HR>
<FONT COLOR="#0000FF"> BLUE TEXT </FONT><HR>
<FONT COLOR="#FFFF00"> MIX RED & GREEN INK </FONT><HR>
<FONT COLOR="#FF00FF"> MIX RED & BLUE INK </FONT><HR>
<FONT COLOR="#00FFFF"> MIX GREEN & BLUE INK </FONT><HR>
</BODY>
</HTML>
and see if the printed colors are "true" to what you see on the computer-screen.
Nov 23, 2009 | Canon I960 InkJet Photo Printer
Bad color in photos-Starts out good then goes to very bad
have you attempted printing directly on the printer via. pictbridge orthe inbuild card reader? this does sound like a problem with the printhead, or connection to it... try taking the print head out andreplacing it, it would need to be re-calibrated again when you do this,but if there is a connection issue this would most likely solve it. its possible also that the feed through for one colour of ink isslightly clogged or not drawing ink correctly (sounds like yellow)-this would mean that its not able to restock its yellow pallet quicklyenough while printing. you could attempt to clean it out yourself, orif its under warranty, see if they will replace your print head for you
Jun 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
Chris
May 18, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Draining the ink!
Printing photos with Epson drains the cartridges alot faster than printing documents. The dpi settings for photos are much higher to get the photo quality. Blue is a base color that helps to mix to create some of the colors in the photos so this is normal with the Epson brand. Hope this helps.
Dec 24, 2008 | Office Equipment & Supplies
Won't print black and white, looks blue
Hi
HP uses a system for black that prints a base ie: Cyan / *blue then overprints it with black...
Sounds like you are either out of black or you have an ink clog?
If so... you need to use a print head cleaner like Magic Inkjet Flush you can get a kit on Ebay.
Good Luck!
Apr 09, 2008 | HP OfficeJet r40 InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
205 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
