Question about JVC Cybercam GR-D200US Mini DV Digital Camcorder
I cannot copy HD recording to JVC DVHS VCR at HS speed
Any help?
    Master:
  • 473 Answers
There may be times when the GR-HD1U playback HD stream thru the 1394 connection is not correctly recognized by the DVHS. Instead, it is recognized as an SD signal stream (only selection of speeds STD or LS3 is possible). To correct this, first perform an i.LINK reset as described in the manual for the VCR (for example, HMDH30000 manual pg 58). Then make sure the GRHD1 menu setting for i.LINK output is set to “SW”, and that the i.LINK switch, located underneath the camera screen, is set to MPEG2. This should allow to copy HD tape to VCR at HS speed.
Posted on Sep 05, 2005
Vcr won't accept tape for recording
Check that the recording tab has not been removed.
If it has, use a small piece of masking tape to cover the hole.
Apr 06, 2011 | JVC HM-DH30000U DVHS VCR
CHAGE SPEED FROM SP TP EP
If I remember correctly there is a switch on the front behind a small door that you pull open.
Jun 19, 2009 | Mitsubishi HS-U110 VHS VCR
Connect vcr to jvc c2033us tv
You will need to put your aerial into the rear uhf socket of the VCR then take another connecting lead (flylead) from the out of the VCR & put this into the aerial socket of the TV. You will now need to select a channel on the TV (best to use channel zero) & tune the TV to the VCR signal. The best way to do this is to put in a recorded tape eg a film /press play/ then tune the TV until you pick up the playback of the film, then store this on the TV. This will give you your VCR channel. You will now need to tune the VCR to your broadcasted stations so that you can record.
Apr 01, 2009 | JVC Televison & Video
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
The video is B&W-AUDIO ok
This is not a tracking issue. There are capacitors on the head/drum assembly that are failing. This prevents the motor servo from keeping the heads spinning at the correct speed. This will show up as a loss of color. There should be 3 caps on the head/drum assembly that should be replcaed. Please note that they may be surface mounted caps which are more difficult to replace if you have not done it before.
Dan
Feb 03, 2009 | Mitsubishi HS-HD1100U DVHS VCR
Change tape speed from SP to EP
hi!u can download a copy from http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
u will have to make a free and simple registration but its worth!
hope it helps!
Nov 04, 2008 | Mitsubishi HS-HD2000U DVHS VCR
Mitsubishi U54 VCR Recording Speed
If you have a remote, there should be a button labeled "SP/EP" or "RECORDING SPEED." Otherwise, I might try looking in the VCR's main menu.
Aug 09, 2008 | Mitsubishi HS-U540 VHS VCR
Do I need any special cables to view or record the footage?
No. The GRHD1U includes a component cable. Another breakout cable provides composite, S-video and audio left and right. For dubbing the footage to a DVHS VCR or computer, a standard 4 to 4 or 4 to 6 (camera has a 4 pin connector built in) pins firewire cable (not supplied) is required.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
How can I play back a tape produced on the GRHD1U?
Tapes may be played back by the camera itself. If the tape was shot in the 720P (HD) or 480P (SD) modes, it cannot be played back on a standard DV VCR or camera. Tapes shot in the 480i (DV) mode are completely compatible and can be played back on any DV VCR/camera. In addition, tapes can be dubbed to a JVC HD DVHS VCR via the firewire connector.
JVC Cybercam GR-D200US Mini DV Digital Camcorder Logo
193 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
