Question about HP Compaq Presario R4000 Notebook
Laptop will not boot up
I was running Itunes and it froze. I had to shut my computer down, and tried to start up again and it won't. I can't even get any screen display.You can hear it starting, see the hard drive indicator light start, then stop suddenly. It is powered up, and even tried putting in the recovery disc and it tries to log on that, but same thing happens, the HD light comes on for sec, you can hear the cd turning, but then it stops. No opening screen display of any kind. This is a new hard drive, recently replaced and has been working fine. Computer is 3 years old.
  • 1 more comment
  • Anonymous Oct 26, 2008
    My Compaq Presario R4000 laptop will not boot the Windows XP. It was working fine until I was down loading family videos onto the unit. Up till today, the unit accepted the videos. This time it did not recognize them and the unit evenually froze. Upon re-booting, the Companq sysmbol shows up, asks me what mode I want to start and no matter what I choose (Regular, safe Mode etc.) it will not boot Windows XP. Rather the sceen stays blank, even after a considerable amount of time. I noticed the HD light icon does not respond. Is the hard drive shot?
  • RadzPrower Nov 07, 2008
    Today my laptop has suffered a similar problem. I was using Adobe Flash to make a flash video when a message came up telling me my battery was low. I decided to put it into hibernation mode to prevent me from loosing data or my place in my work. Start, Shut Down, Hold Shift to switch to hibernation mode, enter.
    This is where things got weird. I'd done this hundreds of times before, but this time it was VERY slow. The windows slowly disappeared from the top down, then the Windows logo and the status bar showed up. The total time it took to go into hibernation was probably a minute or more compared to about 15 or so seconds normally depending on what I had open.
    I tried starting it up about an hour later after I'd found an outlet and let it charge a little before I booted it up. The fans and HDD seem to start, but the display doesn't show. I'm not entirely sure if the fan and HDD continue to operate since I didn't really pay that much attention and I'm in class right now so I can't check. But I do believe that when I turn the laptop on, the monitor flashes like it always does when the POST screen comes up and also goes off just like it would normally if Windows XP was starting.
  • mandykeith08 May 19, 2009
    mine is doing the same thing ,i got on ebay and purchased a boot cd and i am going to try that. they say it will boot it and it should run like a new one! goodluck!
ELVIS...I have this information on my acer aspire 5315..." WARNING...RocketDock had trouble loading your icons last time it was run. Should RocketDock load the default icons?' It has a yes or no option but i have selected these on different occasions but still it is not responding. Please help
Posted on Jun 30, 2009
  • 21 Answers
There could be several reasons for these problems and all of them are something that a tech or a computer savy friend needs to check for you.
Posted on Jan 19, 2009
Samsung sens g25
Reinstall your video driver just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
Check for registry issues
Start the computer in safe mode and run System Restore
If this didn't help you then simply get the Intel software partner reliable program "RegInOut" to fix these errors which causing black screen.
Thanks
Jun 13, 2013 | Computers & Internet
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using it...
holding the fn key on boot will start the pre boot diagnostics if theyre clean then the heatsink and fan need cleaned out as they get blocked with dust, there should be a panel that you can remove on the back
Feb 24, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using...
Make sure the cooling fan for the laptop is not obstructed in any way or is not dirty. It's pretty common for a laptop to get plugged with dirt from normal use. Get a can of air and blow the machine out to remove dirt, lint or debris.
You could also have a defective battery, but try cleaning the machine first.
Feb 24, 2011 | Computers & Internet
Laptop locked up this morning. Went to reboot, Irt
Hi. Try to tap F8 during start and then try safe mode then reset it again. If this doesn't help try to clean you computer inside it looks like overheating problem.
Oct 15, 2009 | Computers & Internet
Toshiba laptop stuck
try to use the restore cd.. .. select boot from the cd/dvd and boot the repair features with the OS
look at the boot screen that initially shows up and get in the setup.... switch the cd/dvd to be the boot device that starts first...
run the cd/dvd installation normally until you find a repair feature.....
then follow the standard repair method
Sep 30, 2009 | Computers & Internet
Hp dv6700 does nothing
The liquid would have shorted out the laptop and rusted the boards!
You need to go to google and find the serivce manual for the laptop and take it again to clean all the boards up.
the service manual is very easy to follow so you should have no problems at all.
if not you may be best of claiming a new one on your house insurance
Apr 06, 2009 | HP Pavilion dv6000z Notebook
Laptop won't boot up
That shouldn't affect the laptop booting, hold down the power button for 10 seconds, it shoul boot up., if not then remove the battery and replace it. then try it again, good luck, Gym
Dec 18, 2008 | HP Compaq nc6000 Notebook
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
It wont start up
Could be this is a driver error on boot up, when it starts to boot up keep pressing F8, this will bring up the safe mode menu, look for the line and highlight 'Last Known Good Configuration' and press Enter. If this works all is well, but if not press F8 again o boot up but this time highlight the line 'Start Windows in Safe Mode'. If the laptop then boots up in safe mode without shutting down, run your anti virus and spyware programmes. If non found and the laptop still has'nt crashed, then it's a driver problem (as not all the drivers load up in safe mode) and you will need to try a system restore to before the problem started.
Oct 30, 2006 | Acer TravelMate 4150LCi Notebook
Computers & Internet Logo
3,182 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
