Question about Logitech 931249-0403 Mouse
Mouse When i plug in my mouse my computer dosn't find the USB port it was used on my old labtop and it worked but when i tryed it on this one nothing happed not sure if u need this but here M/N:C-BS35 P/N: 831487-0000 PID: LN52189
  • Anonymous Apr 27, 2009
    What if you don't have the software CD anymore?
    President:
  • 8,637 Answers
Did you plug in the USB receiver for the Mouse?
Normal 0 Try disconnecting the Mouse from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse to the USB port, do so and it should work. Let me know if it doesn't and I'll give you additional info. Bud
Posted on Jan 19, 2009
Mouse not working
Hi!
Plug it in the port, USB port. It will function better if plug into 2.0 USB port.
Jan 24, 2014 | NexxTech NWOMMI Mouse
I bout retractable travel mouse and doesn't seem to work on my labtop
It may have a manufacturing defect. Have you tried it on another computer? If it works on another computer, see whether it works when connected to a different USB port on the laptop. If it does, then you may have a bad or damaged USB port on the laptop. If it works on another computer but still does not work on the laptop when connected through an alternate port, then see whether some other device will work when attached to the laptop's USB port. If neither the mouse nor the other device work when connected to a USB port, then you have a problem with the USB controller. If an alternate device does work when connected to the USB ports of the laptop, and if the mouse works when connected to another computer but does not work when connected to the laptop, then you have a software problem, and probably need to change the mouse driver in a control panel or setting in the operating system of your laptop.
Oct 27, 2013 | Maxell Optical Travel Mouse With...
My wired mouse on my desk top computer (windows XP) won't move. How do I fix this? I opens the mouse, cleaned it, made sure mouse. keyboard etc. was correctly plugged in, nothing has worked. Please help
It would seem that your mouse is broken. They easiest way to tell if it is your mouse that is broken is to plug that mouse into another computer. If you have another computer you should try plugging your mouse into that one to see if that works. If you don't have another computer ask a friend or family member who does to help you out. It seems most likely that you have a ball mouse using a PS/2 port, the plug pictured in green. Fortunately mice are relatively inexpensive. Even laser mice, which are more accurate, easier to use, and don't jam up with lint and dust build up. If the issue is not your mouse, it may be the port to which your mouse is plugged in. If you are using a PS/2 mouse and your port is no longer working you can get a new mouse that uses a USB port. If your current mouse is using a USB port try changing the port it is plugged into. An example of what a USB port looks like is pictured below. It is the picture of the two ports with the USB logo next to it, a dot with lines going to another dot, a triangle, and a square.mthealey716_1.jpgmthealey716_2.jpg
Dec 13, 2010 | Microsoft Windows XP Home Edition
Mouse can not work
this is usually do to a port going out or the total failure of the mouse.. or if it's a rather old mouse, the ball underneath is too worn to work.
if it's the port, there are 2 kinds, one is a round port (PS/2), you will have to turn off the computer to remove the mouse from this type of port.
if it id the round ps/2 port, you will have to either get a new mouse using usb, or you can try a new ps/2 based mouse.
REMEMBER you cannot plug in or remove a ps/2 mouse while the computer is still on!
The next port, and most common is the usb port. it's a small rectangle.
You most likely have atleast 4 of these on the back of your computer, and most of the newer computers have 2 on the front, sometimes in a hidden panel.
Sometimes if you are a windows user, windows will set a usb port aside for what normally resides there, and a mouse in a port that usally houses a printer usb plug will make windows not see the mouse sometimes.
Removing a usb port mouse is rather easy, you dont need to turn the computer off to do so.
Before considering replacing a usb mouse, try putting it into another usb port. sometimes this will work. also, see if the lights are working underneath when plugged in. (optic mouse, not ball mouse).
if you have determined that your mouse is broken, then the next step is to replace it. bestbuy sells mice for about 25-30 dollars.
if you dont mind waiting 3-7 business days, a reputable online retailer like 3btech.net can sell you a mouse for about 15-20 dollars, and 3btech does not charge for shipping.
usb mice can be found here:
http://3btech.net/keyboardsmice1-us.html
ps/2 mice can be found here:
http://3btech.net/keyboardsmice1-ps.html
Jun 17, 2010 | Computers & Internet
I bought my mouse and it just stopped working.
If tat has an USB interface, try inserting it in other usb ports. May be due to conflicts of drivers
Sep 07, 2009 | Apple Mouse
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
What is the difference between mouse connected to mouse port and mouse connected to usb port ?
Nothing other than the port that they plug into. New mice will typically use USB ports and older mice typically use a PS/2 port. Careful buying a new PC or Mouse, make sure that your computer has the port that is needed for the Mouse to plug into.
Please rate, thanks.
Mar 09, 2009 | Logitech Wireless Optical Mouse...
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
Power failure after connecting the mouse
Hi sambi,
If you are currently, working on PS2 mouse port which is the error occurred as stated in your problem. Try to used other PS2 mouse which working on the other pc maybe there was a short circuit on your old mouse. If the problem persist, You can use the alternative way by using USB port to plug your optical mouse.
Try to look for ps2 to usb port converter in the computer stores maybe you can still used your old mouse.
Hope this will be helpful to you.
Best Regards,
Philip
Oct 24, 2007 | Computers & Internet
Logitech 931249-0403 Mouse Logo
337 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
