On printing business cards with Windows Vista,card prints out perfectly on practice sheet but prints on the margin to be torn off from Staples stock. Both are Avery #8371 template.
  • 1 more comment
  • hmonalisa Aug 26, 2008
    My printer is a HP Officejet 5780. Will print practice sheet perfectly but will print business cards on margin to be torn off. Both are Avery #8371 template.
    I have told you my printer is a HP Officejet 5780 all in one4. and is always working perfactly except for this one business card glitch with Broderbund Print Shop & Version 15.
    It has printed other business cards just fine.
  • 19,396 Answers
Ensure that you set the printer properties to the right Avery template, ensure also that original file is on right Avery template. If it is a word file for example start the file as avery template with right format number
Posted on Aug 26, 2008
  • 157 Answers
HP printers have bugs on windows vista .. this is a common bug
Id recommend you use a PC with XP installed
If you dont have one maybe use a freinds
Hope this helps
Jigsaw
FixYa Team
  • 6,487 Answers
Can you please provide us the complete details like the barnd and model of your printer and also if this was working fine before, so we can help you better...
Thank you,...
  • Mark Gil
    Mark Gil Aug 26, 2008
    I believe there's a settings that you need to adjust from that Broderbund Print Shop & Version 15. just to fit the business card when printing, let me double check that out...
    Master:
  • 848 Answers
What is the make of your printer ?
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
HP Photosmart C4795. Can't get business cards to align correctly at top. Alignment is perfect on plain paper, but starts too high on card stock so every one is lined up wrong. What am I doing wrong? Using...
In printing properties and printing preferences be sure and tell the printer you're printing labels, it allows more time for the card stock to reach the starting point.
Jan 05, 2010 | Office Equipment & Supplies
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Printmaster gold will not center print job
    there should be a box to allow you to enter figures for the margins in the setup print job bottom margin etc put a figure in here usually centimetre or millimetres adjust untill your perfect print test page
    Find the setup box ! might find it the drop down menu s at the top of the page good luck!
    Dec 26, 2008 | Broderbund PrintMaster Gold 16 for PC
    Problem printing business cards
    I had this problem today and think I've figured it out. Take a sheet of plain paper and two little pieces ot clear 'scotch' tape. Tape the blank sheet behind the business cards at the top/feeder edge and try again. You may need to tweak it a bit more but it stops it from printing so far up.
    Jul 19, 2008 | HP Deskjet 3845 InkJet Printer
    in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
    Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
    I am trying to print double-sided copy on card stock
    HI there sounds like there is a blockage in the duplex area that is not holding any sensors down. Check the duplex area for torn paper, failing this it maybe a sensor problem which will then need a engineer.
    Hope this helps
    Thanks J
    Jan 30, 2008 | Brother HL 5250DN Laser Printer
    Only prints business cards correctly on plain paper, but not on the card stock.
    I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
    Oct 21, 2007 | HP PSC 1410v All-in-One Printer
    261 people viewed this question
    jasbo
    jasbo
