Question about Toshiba D-VR4 DVD Recorder/VCR
Toshiba Recorder I already did that and it did not work I unplugged from the wall and from the back of the recorder
    Master:
  • 848 Answers
Is your player able to get proper power supply .........and also are you getting any error message when switching on the player .......
Posted on Aug 26, 2008
    Scholar:
  • 93 Answers
You have the answer for this on http://www.tacp.toshiba.com/customersupport/
  1. Select the year
  2. Select the model
  3. Go to the knowledge center
Regards
http://www.MyTechGuru.US
    Genius:
  • 2,028 Answers
Could you post the exact problem again, assuming you already posted it once? All I can see is that you tried a suggestion and it didn't work, I can't see the initial problem.
  • Ryan Rogers
    Ryan Rogers Aug 26, 2008
    Still need more info, please.
  • Ryan Rogers
    Ryan Rogers Sep 02, 2008
    Any more info would be helpful.
    Genius:
  • 1,847 Answers
Are all the cables connected properly. check the user manual.
  • Legin Varghese
    Legin Varghese Aug 26, 2008
    With some models of DVD player I know you can download a firmware update on your PC, load it to the DVD player and it wil fix some issues
  • Toshiba Master
  • 6,487 Answers
I believe you can reset the player , so try resetting it and hopefully that will take care of the porblem since turning off the player didn't work.....
Good luck.......
HOW do I clear Toshiba DVD recorder error E 4 54040901
You can unplug it from the wall and it should set the dvd player back to factory specs. If there error still comes up, you can try a cleaner disk. If still having issue can switch types of disk. If using + try the - or vive versa. Last thing to try would be the speed. There is S, SL and SLP. Change it and see if will work for you.
Feb 06, 2016 | Toshiba Televison & Video
DVR Set to DR-2, can't set it back to DR-1.
Just unplug the DVD cord from the power source and re-fix it after a minute or so. It's so simple. Please let me know if it works for u. setornam123@yahoo.com
Sep 26, 2010 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Will not power up but is still showing time
I changed my IR code by accident and now nothing works. I can not get back to the IR 1 code. Everytime I hit a button the DR3 appears but nothing works. How could I fix this.
Oct 01, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba RD-KX50 HDMI freezes the recorder.
Press the standby button for about 10 seconds and will reset the HDD you may lose what you have on the HDD but will fix it.
May 07, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Remote control
lift up the flap on the remote. Press setup and 2 at the same time. This will activate your remote to RD2 the same as your recorder.
Jan 08, 2008 | Toshiba RD-XS32 DVD Recorder
Toshiba DVR recorder incorrect disk message
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Dec 03, 2007 | Toshiba D-VR4 DVD Recorder/VCR
NO MENU SCREEN ON TV
You MUST connect the recorder to the Tv with a SCART cable that is why you are not seeing anything.
I suspect you are using only the RF or Ariel Cables
If you have it connected with the scart cable you must choose the AV channel on your TV remote.
Nov 13, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Recorder Stuck in WAIT mode
On our units we unplugged the bad network connection and all was well.
Apr 29, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba DVD recorder problem
Generally, this problem is caused by bad sectors or other problems on the hard drive and can be resolved by going into the setup menu and re-formatting the hard drive. Of course, all recordings on the hard drive will be erased, so spin them off to dvd first. Be sure to have unplugged and replugged the unit immediately prior to going into the setup menu (don't try to record anything). If this doesn't work, no-one will repair this unit locally, as it must be returned to Toshiba's(TACP) depot for repair. Best of luck.
Feb 02, 2007 | Toshiba RD-XS52 DVD Recorder
Open Questions:
See all Toshiba D-VR4 DVD Recorder/VCR Questions
Toshiba D-VR4 DVD Recorder/VCR Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
