Home | Xerox | WorkCentre PRO 128 Grayscale Copier | Lost document in feeder
Xerox WorkCentre  PRO 128 Grayscale Copier
Problem for Xerox WorkCentre PRO 128 Grayscale Copier
By Beancoji on Aug 26, 2008
I made a copy of a stack of documents and there were three checks in the stack, and only two checks came back out. I've lifted all the parts that open and I can't find it.
Best Solution
posted on Aug 26, 2008
Helpful)
tryit
Rank: Guru  Xerox Expert
Rating: 89%, 1266 votes
They may have gone under the white pad that is on the borrom side of the feeder. it is just velcroed on so remove it and see if theey are there.
There is a very remote chance they went under the scan glass, or lift the right hand side of the feeder, where the documents normally come out and see if they are laying there some odd way.
Also they could have slid out the bottom of the feeder and drifted either under or behind the machine.
Was this helpful?
Yes
No
Popular Solutions for Xerox WorkCentre PRO 128
Questions and Unsolved Problems for Xerox WorkCentre PRO 128
Do you recommend Xerox WorkCentre PRO 128 Grayscale Copier?
Answer
Answer
my brother mfc 210c says it will not clean
Answer
I am trying to scan a document, save it and then send it a an email attachment
Answer
error 116-364 and Xerox dealer support doesnt seem to be sure :(
Answer
Job Status Completed with error(016-799) The Troubleshooting guide solution was: The print parameter... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Xerox WorkCentre PRO 128...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1507
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
