Question about Casio Cassiopeia E-125 Pocket PC
CASIO E-125 has no backlight
Need help please: My CASIO E-125 is still working but there's no backlight. I can see it's working in the background but without backlight it's so frustrating. Can anyone show me how to fix it or where I can have it fixed? THis PDA is out of warranty though. Thanks PDN
    Master:
  • 551 Answers
Pretty common problem, and is normally one of three possibilities: 1. Ribbon cable that connects the backlight daughterboard to the motherboard connector has gone bad, or contacts oxidized. 2. Daughterboard itself has gone bad... 3. Power problem or cpu problem not activating upon powerup. Not as likely. 4.The fluorescent tube itself may has blown. The cure: carefully disassemble your 125, clean the ribbon contacts on both ends of the tiny ribbon cable, be careful, it is very fragile. If that doesn't work, find someone who has a E125 and swap out ribbon cables and see that works, that will at least tell you if the cable is bad or not. If that doesn't work, swap out daughterboards. If that doesn't work, sell it for parts on EBay and buy a new one, because anything else will probably be too expensive.
Posted on Sep 05, 2005
  • deton8 von Splosion Dec 27, 2010
    eBay indeed...
    Try not to be a dishonest slug... tell the truth when you "sell" it for parts...
    Anything else is just plain stealing... Saying "good for parts" when you know it is NOT...!!!
SOURCE:
I have problem with backlight. first it work normaly but after it did not work. maybe it is switch of. i have not user manual. second problem is that i do not hear signal. I have casio g 7302Rl
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Dec 25, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Backlight on DW6900
You cannot change the light. It is an electro-luminescence layer behind the display. It is something like a large LED. They are designed to not be very bright to save battery life. I have a number of Casio watches. They are all not very bright. Also the non silver background type watches tend to be much darker than the silver background with black symbols.
Jan 29, 2018 | Casio GShock GShock Youth Culture Theme s...
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
Backlight doesn't work
Go to this link; http://world.casio.com/wat/download/en/manual/ and enter the four digit code on the back of the watch, you should get a user manual - i do think you are probably right however. Hope this helps :)
Apr 18, 2007 | Casio G-Shock GW300A-2V Wrist Watch
Casio e-125 problem
Sounds like you might have a bad cable or something. Did you try plugging ppc into its power pack while using the cable?
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
E-125 dark screen
Bingo! You hit the problem on the head. If you can still see an image, albeit extremely faint, and the Casio is still working, i.e. playing an mp3 file or whatever, then you definitely have a problem with the backlight. More times than not, this is either a daughterboard problem or a connection problem (rarely have I seen an actual bulb failure though it can happen). One of the more common causes is the tiny ribbon cable connector on the daughterboard. You might try to disassemble it, clean the contacts of the ribbon and reassemble the device. I've also heard of people squeezing in the side of the case to temporarily effect repairs...this is normally more ominous.
Help with E125!
Before turning off the device close all applications running in the background. If this solves your problem it is time to do a full cleanup & adding some application like Gigabar or KillMe to help you quickly close the unused applications to free required memory.
CASIO E-125 no backlit
Usually the ribbon cable connection that powers the backlight is the problem.If you remove the four screws in the back and take off the back cover. (note that there are two tabs on both sides of the cover half way up)You can see the white ribbon cable on the left above the battery back housing. Gently wiggle it and see if the backlight goes on. The cable is attached with a small brown insert that holds it in. It is removable so you might be able to get an electronics shop to replace the cable connection or the cable itself.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Cassiopeia E-125 & Nokia 7650
You will need 2 things. Software to load on your E-125. The included Cd with your Nokia should have it. You will need a special cable to connect Nokia to E-125. I don't know where you will find it easily. There is a firm in Finland which makes all kinds of cables to connect different models of Cassiopeias to different models of mobile phones - essentially Siemens, Nokia & Ericsson. They run about US$ 50/= Last time I saw their listing it was 4 pages long. You might have to do some searching on the net or contact Casio for information. Hope this helps.
E-125 Owners BEWARE!
Unless a Casio technician has looked at it don't take Casio's word for it. There is an inverter PCB which converts the DC to high frequency AC for the fluorescent back light. lamp. This is available & can be repaired / replaced. There is also an issue with the E-125 backlighting which simply requires resoldering of a connector on the main pcb. Then there is the fluorescent lamp itself which can go bad & may be replaced. So DO take your device to a well equipped competent technician to look for the precise problem.
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
178 people viewed this question
Top Casio Computers & Internet Experts
k24674
Joseph Hoffmann
Joaquim Martins
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
