I installed a creative xtreme audio card under xp. All works fine, except Youtube. With Youtube you get a burst of sound, then the video slows to a crawl, the audio just gurgles, and the mouse reponse drops to practically nil. I have done a clean boot several times and re-installed flash. It doesn't help.
  • 12 more comments
  • plillies Aug 26, 2008
    The Internet speed is definitely high enough for streaming. I am running other computers and devices with no streaming problems.
    I have tried both firefox and explorer. Same problem.
    I am running at 2.2 GHz and have 1G of RAM.
    Well that was interesting. After I ran the K-Lite Codec Pack, I no
    longer lost control of my mouse. However, same symptoms as before as
    far as the audio goes (burst of sound followed by low gurgling), but
    now I have control of the mouse.
    But because I could use my
    mouse, I was able to toot around in the task manager. CPU usages spikes
    upward from around 10% to 100% when you start a Youtube video. The
    video, BTW, is extremely jerky.
    Comment by plillies, posted on Aug 26, 2008
    Well that was interesting. After I ran the K-Lite Codec Pack, I no longer lost control of my mouse. However, same symptoms as before as far as the audio goes (burst of sound followed by low gurgling), but now I have control of the mouse.
    But because I could use my mouse, I was able to toot around in the task manager. CPU usages spikes upward from around 10% to 100% when you start a Youtube video. The video, BTW, is extremely jerky.
    I have re-installed xtreme audio from the original CD multiple times. That won't fix it.
  • plillies Aug 27, 2008
    Well, it might seem a nice thing to try now that my mouse works better, to re-install the drivers from the CD once again, but before I waste time doing that, I thought I would just run dxdiag again to see whether the mouse really was working better.
    When I went to the Dxdiag Music tab and clicked Sound Blaster X-Fi Xtreme Audio, no sound came out. Instead, I once again lost control of the mouse and barely managed to shut the PC down. Shut down was very slow and disorganized. Some high priority process was obviously not wanting to let go.
    The computer is 3 or 4 years old. Although it has 1G of RAM I am wondering whether perhaps the RAM is too slow for the audio board. If you offer an explanation along these lines, I would like to understand why it only fails with Youtube and similar files.
    Excellent. This could be the answer. I seem to be using a Radeon 9600 driver. Trouble is, according to ATI, that is not an option for an integrated video such as I have. This is a rather old computer. Is there an easy way to find out what my video hardware is? I no longer have the motherboard documentation.
  • plillies Aug 28, 2008
    Well, it turned out I do have a Radeon 9600 card installed. The drivers were from 2004, so I updated them. I also updated the mouse driver. It didn't fix anything. Same symptoms as before and still crashes when you test the audio board in Diagdx.
    One other detail. When I updated the video drivers it said:
    "Severe Error: No GUID"
    That's probably not good.
  • plillies Aug 30, 2008
    It looks like you guys aren't going to be able to help me. Someone suggested I might be having some kind of system conflict. I have noted the IRQs displayed on the boot screen. Does this lead to any suggestions?
    5 - OHCI
    12 - OHCI
    11 - EHCI
    11 - Network controller
    14 - EDI
    12 - Single comm
    5 - Multimedia
    12 - Display
    9 - ACPI
  • plillies Aug 31, 2008
    Well, I think I found out what was wrong with my computer. It had a virus. There were three components:
    getsn32.dll
    hljwugsf.bin
    uoyzsydz.exe
    The latter file was hopelessly sprinkled throughout my registry, so I'm going to have to re-install XP.
    Hopefully all will work normally afterwards.
  • plillies Sep 05, 2008
    As I said, I had a horrible virus and had to toast my registry to get rid of it. What I did is copied the repair registry over top of the registry that was there.
    Now the virus is probably gone, but all I have is a bare bones XP system with no connection to the internet. I am wondering if anyone can explain how to get my internet connection back. I have a high-speed LAN going through a router.
    I figure if I can get my connection to the internet back, I can re-install all my software without reformatting.
    The make a new connection wizard does not provide the options I need.
    Any suggestions?
    Brigadier General:
  • 6,966 Answers
On the re-installation of your device drivers, pls post back make & model of your motherboard.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 05, 2008
    Master:
  • 788 Answers
Have you tried updated drivers from the Creative website. Also make sure the chipset driver for your motherboard is up to date since this card is PCI-Express isn't it? If you running Vista I know that have been problem with creative drivers, make sure you are running SP1 for Vista. And you may not have much luck if you're running 64bit Vista or XP.
Posted on Aug 27, 2008
    President:
  • 2,961 Answers
I assume you uninstalled any previous sound driver, and you have the latest driver from the sound card web site, as it sounds as if you have a conflict between your sound and video driver, hence the mouse problem, check for the latest video driver and sound, if there are newer versions uninstall the old ones first
    Master:
  • 521 Answers
Ram helps in increasing speed and the slow speed will give you this problem.now when every thing is working properly except the jerking problem.just uninstall and reinstall now.with high capacity ram.and also recheck your internet speed.before installing.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 26, 2008
  • 19,396 Answers
Update internet explorer, download here latest one:
Internet Explorer: Get It Now
  • 2 more comments
  • Ginko
    Ginko Aug 26, 2008
    If you have shared RAM on your video card, the card is using system RAM, add a 1 GB module, they go cheap nowadays.
  • Ginko
    Ginko Aug 27, 2008
    It looks like the two things are related. If the mouse and the audio drivers are probably in conflict. You should reinstall both of them.
    More likely it is the audio driver or the Sound Blaster hardware itself that is giving troubles.
  • Ginko
    Ginko Aug 28, 2008
    You have a conflict involving the video drivers, it is caused by several Windows registry values that does not get reset when you reinstall Windows.
    Only easy way to fix this is reinstalling Windows from scrap.
    If you do not want to reinstall Windows you will have to work on windows registry purging some video related registry entries.
    Here you find the How to, you will need to go over first page and read the following of the procedure, read also feedback from users one got Guid error (DriverHeaven.net).
    Do a backup of your files first.
  • Ginko
    Ginko Aug 31, 2008
    It is not someone suggesting it, is that you have a conflict between hardwares, probably in use of memory resources.
    "Severe: Error: No GUID on video section"
    This is not an IRQ conflict, when it is an IRQ conflict you see immediately on device properties, and usually you see an yellow exclamation mark on device list.
    IRQ means Interrup request, it is the priority in using the CPU during a CPU cycle.
    When is IRQ conflict you usually Fix it just reinstalling the drivers, in your case here you need to purge registri entries and apply a patch (or do a fresh installation of Windows).
    Try putting a corded mouse to test the system, if you do not have the problem decide between replacing mouse or attempting to fix the system.
    If you still have the problem, mouse disappearing was only collateral, only choice is fix the system problem.
    Again here is the how to : Here you find the How to.
    I dont care what you read from others experts, someone may had been not very precise.
    Read here solution on first pages, Here you find the How to.
  • 1,031 Answers
Its your processor and ram size high enough to accomodate it.check your anti spy and anti ware application for possible interference
  • Starnley Johnwells
    Starnley Johnwells Aug 26, 2008
    you equally the space on your hard disk and try using qick time check the connection speed setting
    You may need to change the connection speed setting for QuickTime:
    1. Go to Edit, then Preferences, and select QuickTime Preferences.
    2. Click the Streaming tab and set Streaming Speed to the appropriate choice, depending on your internet connection. If you do not know the connection speed, leave it set to Automatic.
    3. Close the control panel and then try replaying the file.
  • 1,879 Answers
Video & Audio mixed = Movie
YouTubero since March started encoding with aac stereo format. You got all audio codecs needed installed ?
  • monk3ybidzness
    monk3ybidzness Aug 26, 2008
    You got no problem with your hardware - It's CODEC
  • monk3ybidzness
    Follow MyTechGuru 's suggestion / intruction
    Scholar:
  • 93 Answers
Try downloading the Registry Fix for Flash player
http://depositfiles.com/en/files/1492978
OR
  1. Download and install K-Lite Codec Pack version 3.3.0 Full from here or here, or choose other versions from more mirrors here. You can deselect most components that you don’t need, except Codec Tweak Tool under the Tools section.
  2. After installed, click on Start button, then go to All Programs-> K-Lite Codec Pack -> Configuration -> Codec Tweak Tool.I installed a creative xtreme - ded8f20.jpg
  3. In the Codec Tweak Tool window, tick the check box next to [Registry] Fix non-working system sound.
  • 157 Answers
The problem seems to be with macromedia flash player
Go to the adobe website www.adobe.com and install the updated version of flash player and let me know the result
Also check ur internet connection and that ur not throttled due to downloading over ur quota
Cheers
JigSaw
FixYa Team
Dont forget to rate this solution as FixYa !!!
  • John Smith
    John Smith Aug 26, 2008
    K-Lite Codec Pack version 3.3.0 has spyware and a virus
    Beware !!!
    Genius:
  • 2,028 Answers
Try downloading a video player for web viewing. You can find a couple that are youtube specific at filehippo.com or download.com I recommend downloading one or two that covers most video formats from the web, this way you won't have any problem at other sites you may want to watch videos from.
  • 4 more comments
  • Ryan Rogers
    Ryan Rogers Aug 26, 2008
    Here's a couple of links for downloading video software. On the first, about half way down the page, VLC is a good one (I use it), and the GOM is another good one. The second link is primarily for watch video through your browser, try a few and see which works best for you.
    http://www.download.com/Video-Software/?...
    http://www.download.com/Video/3150-13458...
  • Ryan Rogers
    Have you tried the programs for web video viewing that I posted?
  • Ryan Rogers
    Ryan Rogers Aug 27, 2008
    That sounds like you have a software conflict somewhere.
  • Ryan Rogers
    1g is plenty for the video. I still say you need a web video viewer, it sounds like the system is have trouble with the video format.
  • Ryan Rogers
    Ryan Rogers Sep 01, 2008
    Sorry to hear about the virus. If you need any other advice, just ask.
  • Ryan Rogers
    Ryan Rogers Sep 05, 2008
    You will need to figure out which network controller you have and download the drivers for it.
  • 6,487 Answers
Just checking also the RAM of your computer, because with video streaming it needs a fast internet connection and also a high RAM of your computer since it will be doing alot of process, if you can update the RAM and see if that will work..
Hope that helps.......
  • Mark Gil
    Mark Gil Aug 26, 2008
    Ok good, if that;s the case I believe everyhting is working fine before you install that Creative extreme, so if you want try to uninstall/reinstall that device then make sure you install the software from the setup CD...
    Genius:
  • 1,847 Answers
Is the internet speed enough to play the steaming video?
    Genius:
  • 3,422 Answers
I suggest you to once try using a different browser like Firefox to play the video in youtube.I'll give you the download link.
I have a creative sound card and i want its sound driver pls tell me what to do vijay
Look at the model number on the Creative sound card. You want to match up the correct drivers.
Once you find it go to Creative Worldwide Support,
http://support.creative.com/
A) Click on the SoundBlaster icon.
B) Click on the soundcard icon that matches yours. I'm going to click on the X-Fi Xtreme Audio icon to use for an example.
Here on the next page we see we are presented with two driver choices.
1) Creative Sound Blaster X-Fi Xtreme Audio driver 1.04.0090
and,
2) Creative Sound Blaster X-Fi Xtreme Audio pack 1.04.0079
The 1.04.0090 audio driver is for Vista, and Windows 7.
It also contains the Creative Audio console.
Click on Show Details to the right for more information.
The 1.04.0079 audio pack is for Windows XP, and Vista.
It also has the Creative Audio Console.
When you have the applicable choice, click on the red Download.
On the next page read the Creative Software License Agreement, then click on Agree.
A small window will come up. Write down the file name.
For example I am looking at Opening XFXA_PCDRV_LB_1_04_0079
The file name is > XFXA_PCDRV_LB_1_04_0079.exe
This is the file name I will look for.
Click on Save File.
A small window will come up on the left.
Quickly look at the heading of this window.
This is where the file will download to.
Look for My Documents, (Documents for Vista), or Downloads, or Desktop, in the heading.
Close all windows, go back to the desktop screen. See the file name?
NO?
Click on Start > then click on My Documents. (WinXP)
Don't see the file name there?
Look for a folder named Downloads.
Double-click on the Downloads folder name look for the file name.
When you see the file name double-click on it. Follow the easy instructions of the Installation Wizard.
(Essentially just click on Next, Next, and Finish. Then restart your computer.
Nov 10, 2010 | E-Machines eMachines Refurbished EMA...
What sound cards will work with Windows 7
Are you using the latest driver ? If yes then maybe it's an corrupted one - uninstall it, run a system cleaner and download (as in  Save, not Run) the latest one from
http://support.creative.com/Products/ProductDetails.aspx?catID=1&CatName=sound+blaster&subCatID=208&subCatName=X-Fi&prodID=14066&prodName=X-Fi+XtremeMusic
After the download has ended close the browser and launch the installer.
Dec 09, 2009 | Creative Labs Computers & Internet
I recently updated my Creative Sound Blaster Xtreme Audio Card and RealTek HDMI Audio Output drivers, and now it seems they won't work with each other. I cannot get sound on my computer.
sound blaster cards are known problem makers they don't play well with others go to start-controll panel-system-hardware-device manager and find your realtek hdmi and disable it its eather 1 or the other you cant have both. sorry
Jun 29, 2009 | Creative Labs Sound Blaster X-Fi Xtreme...
I have a creative audigy Creative Labs Sound Blaster Audigy 2 Sound Card and Creative 7.1 surround sound speakers. When I was using XP all 7 speakers worked perfectly. Now with my newer Vista machine,...
Uninstall all sound drivers for the card. Delete all folder and use search to locate everything related to the sound card. Remove card , turn comp on w/o card. Turn off reinsert card.
Should fix it.
Vista has many,many issues like this.
If you have more types of sound listed in "SOUNDS" delete all but Audigy.
Re-install drivers AFTER you get ALL NEW VISTA UPDATES>
Mastersage
Feb 18, 2009 | Creative Labs Sound Blaster Audigy 2 Sound...
I installed a creative xtreme audio card under xp. All works fine, except Youtube. With Youtube you get a burst of sound, then the video slows to a crawl, the audio just gurgles, and the mouse reponse...
When this happen it is often a problem with the compression codes used by youtube streaming. Often they are not being managed if the browser is not up to date.
Check that the video card is installed properly and can play movies, for example test a DVD.
Try updating Internet Explorer: Internet Explorer: Get It Now
Check also this info from Youtube.
Sep 05, 2008 | Acer Aspire T310 PC Desktop
Creative X-Fi Xtreme Gamer XP SP2 drivers
what the hell are you talking about, the card isn't "vista only"
Jan 25, 2008 | Creative Labs Sound Blaster X-Fi...
Problem with Windows XP recognizing Creative Sound Card
It sounds like a software problem. Though you did the right thing by entering the bios & disabling the onboard sound. That should have been enough. Did you uninstall the old intergrated sound drivers before adding the 24bit card? Just about all the drivers & upgrades for your 4600 through Dell is Creative software & thats why your having a tough time. I would put everything back to how it was. Re-enable the intergrated sound & reboot! Run system restore & check that every thing is running right!! Look at this dell web site for the sound drivers you have at this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If you must, install a upgrade for your intergrated sound. Just so you can uninstall it after a reboot. Re disable the sound in the bios. Do not install your new card yet. While back in windows device manager you should be missing a PCI device. Shut down install the new sound card. Hopefully windows will want the drivers & all runs fine. If still no it could be a bad card (i know what your thinking but it's possible). The only thing left is the regestry is using the wrong PCI device.
Dec 26, 2007 | Creative Labs Sound Blaster Live! 5.1...
Soundcard
This Sound Blaster X-Fi Vista Installation CD is intended to support X-Fi products bought before a Vista installation CD was available in the box.
It supports the following models:
  • SB X-Fi Xtreme Music (SB0460)
  • SB X-Fi Xtreme Gamer (SB0730/SB073A)
  • SB X-Fi Xtreme Gamer - Fatal1ty Professional Series (SB046A)
  • SB X-Fi Fatal1ty FPS (SB0466/SB0256)
  • SB X-Fi Platinum (SB0460/SB0251)
  • SB X-Fi Platinum Fatal1ty Champion Series (SB046A/SB0256)
  • SB X-Fi Elite Pro (SB0550/SB0510, SB055A/SB0510) This CD does not support the Sound Blaster X-Fi Xtreme Audio range (SB0790/SB0792).
This Sound Blaster X-Fi Vista Installation CD includes a full suite of drivers and applications:
  • X-Fi Mode Consoles (Gaming/Entertainment/Audio Creation)
  • Creative Mode Switcher
  • Creative Audio Console
  • THX Console
  • Creative MediaSource 5
  • Creative Smart Recorder 2
  • Creative WaveStudio
  • SoundFont Bank Manager
  • Creative 3DMIDI Player
  • Creative Diagnostics
  • Creative Entertainment Center
For more information on how to obtain a copy of Sound Blaster X-Fi Vista Installation CD, please refer to our regional sites at www.europe.creative.com or us.creative.com.
Windows XP applications do not work with Windows Vista. When launched, it will display a message "The audio device supported by this application is not detected. The application will exit" even though your Sound Blaster card is working properly.
If you have installed any Windows XP applications for your Sound Blaster X-Fi card, it is recommended that you uninstall these (Windows XP) applications before installing the Sound Blaster X-Fi Vista Installation CD. To uninstall, go to Control Panel, and select Programs and Features, and then choose the applications that you need to uninstall.
Nov 18, 2007 | Biostar P4TPT - Motherboard
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
