Question about HP OfficeJet 4255 All-In-One InkJet Printer
Cartridge error Hi, my HP4255 says"cartridge error " on the screen, despite putting in a new cartridge. What can you suggest?
I just had a problem like this. Put the ink one by one to check which one has problem an then change the problem one to restart.
Posted on Sep 21, 2008
Add toner see instructions in front cover to replace toner
Hi
You say you have checked the toner and there is "enough inside", I don't know how you can check this and the error suggests that the cartridge needs replacing. Have you tried a new cartridge ? This is the first step.
Is the cartridge you get the error with a Ricoh cartridge or a compatible. If compatible this could be the cause of your error.
Cheers
Dec 06, 2014 | Ricoh Aficio mp2000 Copier Machine
Hp officejet 4255 all-in-one cartridge Error - See product documentation for details how to slove this problem,,,?
GYou must be using HP56.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP4255 is not a new model however has not cause major problem.
Good practical and durability is good.
It seems like you are out of ink....especially black.
Pls refill or get brand new one.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 13, 2011 | HP OfficeJet 4255 All-In-One InkJet...
Epson stylus dx6000 error message e-02 have tried
Hi
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Oct 14, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Continual error message on printer after replacement of new cartr
Try running deep print head cleaning on the printer and see if that helps
Apr 10, 2009 | HP PSC 1350v All-In-One InkJet Printer
Replaced HP LaserJet 2840 catridges and now [?][?][?][?] ! error
The OEM cartridges have a chip on them. If the aftermarket supplies do not have the right chip, missing a chip, etc., the machine will not recognize. Placing the old cartridge back in without any toner can give off the same message.
Try rebooting the printer without a cartridge in. Then install the cartridge, either one, and see if that helps. If not, wait for the OEM to arrive.
Jan 27, 2009 | HP LaserJet 2840 All-In-One Printer
Cartridge
did you do a clean cartridge and re alignment first?
http://tinyurl.com/6qcpgy
Aug 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
Ink cartridge
Hi I don't have a 5610 but we recently got a problem from one of our friends. The printer would say there is a cartridge error. After looking and comparing w/ another HP56 cartridge, we saw a very dark area around the nozzles. When compared to a brand new unused and even used cartridge, we only saw a clean copper color and no black area. After checking we realized it was a burn mark. Basically the cartridge had a short circuit that is why the printer won't recognize it. The burn marks might appear also as a very small black spot, we've seen some of the copper lines with a black mark in between. Much like a burned out copper wire. My suggestion is for you to get either a brand new cartridge or an old one and put it in to test. If it recognizes it then most likely your cartridge had a short circuit. If it is a short circuit, dont' bother refilling it. Crack the casing and give it to the plastic recyclers. Hope this helps.
Jul 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Cartridge error
remove the cartridge & install the new one cartridge other wise
May 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP OfficeJet 4255 All-In-One InkJet Printer Logo
109 people viewed this question
Seeker5211
Seeker5211
