Question about Panasonic Microwave Ovens
Microwave runs 6 seconds and kicks off - Panasonic Microwave Ovens
  • Panasonic Master
  • 9,098 Answers
According to a recent report we received, if it stops after 7 seconds, it has a problem with the inverter.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 01, 2008
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Tip
Profile series kicks out during operation
My GE Profile series Spacemaker Microwave, model JVM2070BH002 after we set the cooking time will kick out after about 3-5 seconds. This is sporatic. It will work for a week and the kick out for 3-4 times.
on Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave cyle starts but kicks off in 5 or so seconds. Have to reset clock after which sometime it cycle thru others it kicks off.
Is the PLUG fitting tightly into the wall outlet? any looseness can cause what you describe.
Jul 12, 2011 | GE Microwave Ovens
I have a MV1604ST over the range microwave oven. After I made my daughter's breakfast this morning, the fan kicked on and will not shut off. It has been running for hours. The microwave still works and...
There si a sensor on the bottom of those Micros that is supposed to turn the fan on when it closes, meaning it is hot, then opening when it cools back down. I expect you have a bad thermal sensor. I have very seldom found these to go bad. Another thing that can cause it is a bad door switch back feeding voltage where it is not supposed to. It will make the fan that cools the magnetron run until the bad switch is replaced.
Aug 15, 2017 | LG MV1604ST 1000 Watts Microwave Oven
It runs for 5 seconds then kick off
probably a defective magnetron; or, if it's a inverter model, it could be the inverter iself.
Aug 31, 2010 | Panasonic NN-S561 Microwave Oven
When start Microwave after a couple seconds it stops and asks you to set the clock again.
The magnetron on most all microwave ovens is tied to the microprocessor that drives the display and the input from the keypad.
Check you manual to see if it comes with a self-diagnostic (higher-end microwaves from Panasonic, LG and Jenn-Air come with them) and run it (normally kicked off by a keypad sequence).
If unplugging the microwave and plugging it back in after about 15-20 seconds doesn't correct the problem, then I'd get it serviced if under warranty. Microprocessor will need to be replaced most likely. If not covered under warranty then you're looking at out-of-pocket repair or replacement.
Jun 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JMV8208AAS Jenn-Air runs all by itself
check the door connection. it may be stiking. unplug from the wall and open up, spray wd40 and give it a clean.
Dec 13, 2007 | Jenn-Air JMV8208A Microwave Oven
Slow turn, hot food
underneath the deck is a geared motor that turns the platter. check for non lubricated bearings or slipping gears.
Aug 22, 2007 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
