Related Tags:
This problem should be removed because:
Problem with Maytag MSD2756G Side by Side Refrigerator
ice maker is not dumping
Solutions (1)
Best Solution
Hello, jk
I
am trying to help you out here. Maybe this will help some? I am know on
Fixya as the cleanup expert pro. Which means I spend my own personal
time to seek out customers that maybe have not had there problem yet
solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized
Trouble Shooter.
I have found out that it appears that lots of
customers appreciate my efforts and help. So, I thought I would take
some of my own personal time to
see if I can help you. Even though this Informational site may not have
your exact model or brand, But this site will help you a lot. Here is
the site link about everything you want to know about refrigerator and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-refrigerator.htm
Please
if this helped you at all, if you can find the time and in your heart
to rate my help and some kind words written would be appreciated for my
free help, I would appreciate it. Like I said I
just try to help, If anything this is good information for future
problems. If you felt that my free help was a waist of time for you, I'm
sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive, Appliance, and
Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Suggested Solution (3)
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Mine makes ice and does not dump it... unless the bin is out! I took out the bin to begin trouble shooting and had to stop to answer the phone. While on the phone, I heard the ice drop. Not sure how to fix it yet but it seems like the ice maker is lower than it should be.
Source: Ice maker not dumping ice
After having the refridgerator unplugged for a couple hours, the ice maker is not dumping ice. There are ice cubes made, ready to dump. I...
ice maker wont dump ice. it will refill with
ice maker wont dump ice. it will refill with water after i press the test switch, but wont dump ice until i hit test switch again.
Ice maker will not dump ice there is ice in...
I have a GE Monagram side by side refrigerator The ice maker is not working it has not dumped the ice. I can "feel" the ice is...
no ice
no ice Ice maker does not fill up with water
No ice.
The ice maker is not making ice.
Add Your Solution
Maytag msd2756g change filter light wont go off
Change filter but light wont go off
is a "hard start relay" ( brand name...
a hard start start relay was installen on my refrigerator, it was a electrical 115volts, the relay that was installed...
rsw22eodae not getting cold enough to make ice
Could this mean that the timer is bad. I replaced the Heater element and the Defrost thermostat about 1 1/2 yrs ago.
Fix-O-Meter
106
106 people viewed this problem
- 1 person found this problem to be helpful.
- 1 person is following this problem
Top Maytag Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
