Question about Microsoft Xbox 360 Console
Xbox- No signal to TV
My xbox has no sound oer picture when I turn it on. I have tried a new Av cable but it still doesnt work.
Before this happedned the screen has started to go funny- graphic loked really bad.
  • 4 more comments
  • ma11hew Sep 19, 2008
    my xbox has no sound or picture, i have changed the av cable but still the saem thing happens, i have no red lights so iam a bit confused, all i get when i turn it on is a load of white dots going diagonlt across the screen please help me with this
  • Anonymous Dec 02, 2008
    yea i have the same problem and i only remember after hearing you say that, when i was playing kane and lynch, the graphics went all weird
  • sladeyboy Dec 31, 2008
    played midnight club L.A and my xbox froze i turnt it off then back on again and my tv said no signal and three red lights came up !!!
  • Anonymous Feb 19, 2009
    I get no audio no sound but the xbox is working all green lights. I have just cured it of the red light in the fourth quadrant
  • Anonymous Feb 20, 2009
    have sound, purple lines on screen
  • Jonnyhop Mar 01, 2009
    i have the same problem, part of the sreen went red when playin saints row 2 so i switched it off, when i switched it back on the tv wasnt picking the console up , it was like it wasnt even pluged in, rang micro n they said they didnt know what was wrong with it but my warranty has ran out and it will cost £80 for a repair
    really need help
    jonny
  • 28 Answers
Before the xbox stop working, the graphics where blurry, or small ojects disappear from the screen. I ask this because it could be GPU that is bad. I remember an xbox that I fix that have a similar problem, when you put Final Round, the fighters on screen disappear or their legs or hands disappear. That occur because the GPU didnt have thermal paste on the heat sink and it was causing overheating.
Posted on Aug 27, 2008
TV has no picture, but sound works fine
Are you using the AV input for the XBox or other cable? If you use AV, then use the same input that the Xbox does not show picture, plug in a DVD and see if it works. If it does not have a picture, so 100% your TV has problem.
Aug 11, 2009 | Sony Televison & Video
My xbox turns i hear the log in sounds but it stays blank.
try a different input on your TV or replace the AV cables
Aug 01, 2009 | Microsoft Xbox 360 Console
Av doesnt work
no but what you can do is use a converter adapter that converts rca signals to rf signals also known as antenna or cable plugin good luck
Apr 21, 2009 | Computers & Internet
No picture
You might wanna try another AV cable and another Television. if this steps doesnt work then call 1-800-4MYXBOX to send your xbox for repair
Mar 20, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
No picture...
I would try some of these troubleshooting steps;
  1. Make sure that the AV cables are 100% secure.
  2. Try an new AV cable.
  3. Try your console on a different TV.
  4. Call xbox customer support at 18004MYXBOX
May 31, 2008 | Microsoft Xbox 360 Console
Bad connection?
Cant get picture, sound working. new cables has 5 plugs
Feb 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
782 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
