Question about Bose SoundDock Digital Music System for Apple iPod - White
Bose SoundDock base ripped out
Is it possible to have my Bose iPod dock repaired? Someone pulled out the iPod too quickly and the connector came out with the iPod? Need someone in CHGO area, preferably West Suburbs. THX!
CS
  • 3 more comments
  • spdutt Oct 05, 2008
    Same problem except that the pcb connector is lost and only the flat ribbon cable is hanging out. Can anybody provide a circuit of the connector pcb?
    spdutt
  • nayanls Oct 25, 2008
    i have a similar problem.
    i think the connector that the ipod connects on is loose and has lost its connection from the pcb board.
    i tried to unscrew it from the rear but the screws are also not getting undone.
    can one get just the pcb board on which the ipod is connected?
  • Anonymous Dec 08, 2008
    I have the same problem. Piece was ripped out.
  • Daniel Jenkins
    Daniel Jenkins May 11, 2010
    How old is your unit, it should have a 1 year warrenty...
  • Bobbo Patterson
    Bobbo Patterson Nov 03, 2016
    www.boserenew.com
  • 17 Answers
Ridax has setup a small production for replacement PCBs.  See http://www.chargeconverter.com/shop/connector.htm?connbose.htm
Posted on Jan 17, 2009
Bose repairs
It may be expensive to have someone replace the connector. One option is to squirt some silicone around the base, being careful to still allow contact to be made to the iPod dock connector. You could get a dock extension cable (see link below). It may fit better and will reduce the strain on the Bose connector. If it's still loose, you could glue the extender cable in.
Alternatively, you could use a 3.5 mm audio cable to connect the iPod headphone jack to the Aux-in jack on the back of the Bose. Just living with it may be prudent.
Amazon com 30 pin Male to Female Dock Extender for iPod and iPhone...
Jul 22, 2014 | Bose SoundDock Digital Music System for...
Bose SoundDock will no longer connect to ipod to either play music or charge iphone/ipod devices. Any ideas how to fix or is connector on base damaged and needing repair?
My guess is that the iPod connector in the Sounddock is loose or damaged. You can get a new connector and solder it on yourself (very difficult!) or you could get a replacement PCB at http://www.chargeconverter.com/store/index.php?route=product/category&path=37 which is quite easy to replace (see http://ridax.wordpress.com for description).
Feb 11, 2011 | Bose SoundDock digital music system...
Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Jul 11, 2010 | Bose SoundDock Portable Digital Music...
Docking cradle in bose sounddock
Order Prod Number 041615 , Description: "279103-004 MOD ASSY CRADLE BLK SOUNDDOCK" from Bose spares. Costs £35. Undo the four philips screws in base, romove cover and replace whole cradle assembly. There is a circuit board attached to the main unit by a ribbon cable - you do not need to remove this cable you can instead can thread the circuit board through the old cradle. Then pull out the ribbon cable that connects the new assembly to the circuit board. Installation of new one n reverse. Protect from static by using wrist strap etc.
Sep 07, 2009 | Bose SoundDock digital music system...
Ipod classic 80 gb won't charge in bose docking station.
ipod classic will be charge by running itunes programs... now it you dont use itunes, you cannot charge it,...
Jun 19, 2009 | Bose SoundDock digital music system...
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Bose docking station chip broke off
I had the same problem that the ipod would onl play when I pulled it forward in the dock. Looking closely, I saw that some of the pins on the left hand side of the connector were bent forward, so I bent them back with a needle:
(ie. pushing the pins to the right, as shown here). This solved the problem for me.
If your connector is too far gone, I suggest looking to:
for a new connector for £3-4 or
for a whole PCB (Printed Circuit Board) replacement for £10-15.
Hope this helps...
Nov 26, 2008 | Bose SoundDock digital music system...
Bose SoundDock Digital Music System for Apple iPod - White Logo
2,969 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
