Question about Watches
Watch still not running after battery replaced
  • Anonymous Aug 26, 2008
    I have several Geneva watch faces. Three of them stopped working. I replaced with the same battery and they still do not work.
    Can you help?
  • kdfranco Nov 11, 2008
    After changing the battery, the watch completely stopped. The watch was thoroughly cleaned and a new, tested, battery was installed -- still nothing. I have only worn the watch once and have only had it a short time. Help!
  • 111 Answers
Good morning janet! i think your watch is need to general cleaning or need to repair ,but will you try to test the battery if the voltage is complete at 1.55v if battery is fullycharge the problem is the machine of your watch,try to general cleaning or try to repair,thank you ! god bless !..
Posted on Aug 28, 2008
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    Seiko 5m43 fails run after cell replacement
    Hi, Look on page 11 of your manual for the proper procedure to restart watch after a battery change, or complete discharge of capacitor system. If you don't have the manual, Try this link:
    Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
    I hope this helps you. Thanks, Bill
    Sep 08, 2010 | Seiko Kinetic watch
    How to set the clock how do i no the battery good just got it
    If the watch is not running it's probably the battery. To set, pull the crown out and turn to adjust the time. Push the crown in to run the watch. If the watch is new the battery should be OK but take it back to the store if it doesn't run. If you bought it used take it to any watch shop for a battery replacement. Sears does it for about $8 or less.
    Apr 28, 2010 | Movado 0604771 Wrist Watch
    The watch is not running after replacing the battery, the stop watch part is running.
    It could be that the battery has a poor contact. Try cleaning the battery with surgical spirit and avoid handling its faces.(hold the edges).
    Clean also the watch contacts.
    Feb 03, 2010 | ESQ 07300902 Wrist Watch
    Eddie bauer watch runs slow
    This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
    Aug 06, 2009 | Watches
    I have replaced the battery, but it didn't work. I've tried to reset the watch, but it didn't work. What have I to do to reset the WV-57H after a battery replacement?
    If your watch has any kind of illuminated dial or dial light, you may have found the battery for that instead of the one powering the watch itself. I have one similar and did that same thing only to find that the watch still wouldn't run.  The battery that powers the illumination is larger and in my watch, the battery for the watch portion is half the size and located below and to the side of the other cell.
    Mar 09, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Tropby radio controlled watch, runs slow, even with new battery
    Your watch is need to clean an replaced the old oil in gear shafting that is the common problem of a watch when the old oil is sticky already thats makes the gear moves slowly and your watch is always late . If ever your watch was already clean and replaced new oil and still working slowly then the problem is in the circuit board is near to run out its needs to replaced whole circuit board so its better again. I know this because im a technician in Rolex service center before. Feel free to ask whatever the result.
    Hope it may help you;
    Jan 30, 2009 | Bulova Watch
    Watches Logo
    544 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
