Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
- No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
- One beep - board is working fine
- One long beep then machine shuts down - faulty, improperly installed or missing CPU
- 1 short(Beep) System booting is normally
- 2 short(Beep) CMOS setting error
- 1 long - 1 short(Beep) DRAM ERROR
- 1 long - 2 short(Beep) Display card or monitor connected error
- 1 long - 3 short(Beep) Keyboard Error
- 1 long - 9 short(Beep) ROM Error
- Long(Beep) continuous DRAM isn't inserted correctly
- Short(Beep) continuous POWER supply has a problem
- A two-tone siren, generally caused by overheating or out of specification voltages
- Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
